  3. Zway Bridge
  4. Help with Z-Way plugin
full devices reset
@akbooer Since a couple of weeks/months, we are in the process to redo 5 rooms @ home (kids are moving from room to another room) and of course, I would need to redo a bunch of device name and room name in Zway.. Is there an easy way to tell openLuup to completely start over fresh without having to delete/rename them one by one in openLuup ?
Zway Bridge
I hope this is the correct forum – apologies if not! I have a Raspberry Pi3 with a Razberry Z-Wave card installed. I have installed the Z-Way software and have successfully included a Fibaro Z-Wave switch on the Z-Wave network. I can toggle the switch on and off successfully from my laptop through port 8083 of the Raspberry Pi3. On the same Raspberry Pi3 I have installed openLuup on which I have installed the Z-Way plugin. I can access this through port 3480 on the Raspberry Pi3 from my laptop. Here is where I have come to a dead stop. How do I get access to the Fibaro Z-Wave switch from the openLuup application? I can find no documentation that tells me specifically how to do this. Any help would be greatly appreciated. _John.
Zway Bridge
openLuup Z-Way bridge: Version Log
Master Branch: 2020 Release 4.5 Roll-up of recent changes in development branch.
Zway Bridge
Fibaro Wall plug power metering
PerHP
I have an odd issue which seems to be only for Fibaro wall plugs. They come in to Z-Way with two "electric meter" entrys, one "Power" meter and a couple of alarm entrys. In addition to the switch that is. One of the "electric meters" is KWh and the other one is seemingly Watts, but it stays at 0/-1w. The "Power" meter shows the Watts used right now. When these come into openluup, the wrong electric meter is selected for displaying the Watts, is there any way to manipulate which one openLuup uses? I see that the sub channel for power also is transferred, but it isn't in the data Veraflux is transmitting to my influxdb.. Haven't used the watts reading for anything before now, now i want to estimate when my dryer is done based on power usage.
Zway Bridge
Renaming device name...
@akbooer What's the "logic" behind zway plugin about renaming ? Are you always renaming when starting openLuup ?
Zway Bridge
Fibaro TRV on ZWay/OpenLuup?
Having some trouble getting the Fibaro TRV device working with the ZWay bridge. The device works in the ZWay (Zwave.Me) Smart Home GUI, and creates a number of devices in OpenLuup, some of which appear to have the right variables in it. Changing the XML and JSON files makes no difference. I also tried creating a separate child device for Parameter 67 (using the gui for the ZWay bridge, see below), and setting the XML/JSON types for that device (like I've havd to do for a few other devices). This results in a device that correctly displays the TRV setpoint, but chaning the setpoint in the OpenLuup gui does not result in anything being transmitted to/by ZWay. 20490 49-0 D_ComboDevice1.xml zNode #49-0 49-0-113-8-12-A 49-0-113-8-13-A 49-0-113-8-14-A 49-0-113-8-15-A 49-0-113-9-3-A 49-0-64 49-0-67-1 20491 49-1 D_ComboDevice1.xml zNode #49-1 49-1-113-8-12-A 49-1-113-8-13-A 49-1-113-8-14-A 49-1-113-8-15-A 49-1-113-9-3-A 49-1-64 25031 49-1-67-1 D_Heater1.xml Radiator Bedroom 20492 49-2 D_ComboDevice1.xml multi #49-2 49-2-113-8-10-A 49-2-113-8-11-A 25030 49-2-49-1 D_TemperatureSensor1.xml Radiator Bedroom
Zway Bridge
Z-way token Expiration
@akbooer, I just woke up to a z-way bridge token expiration again forcing me to login again and reload openluup. It appears to happen once a week. It doesn't appear that the auto renewal of the token is working?
Zway Bridge
Why Migrate to Z-way from vera and how?
I expect this document to be dynamic based on inputs from people who try but did not want to completely rewrite it here: https://github.com/rafale77/Z-Way/blob/master/README.md
Zway Bridge
XMLs & jsons without vera
P
Nearly there with the migration .. Is it ok to use older device files or do they get updated from time to time? Now that a fresh openLuup is up and running and connected to Zway where's the best place to source device files without vera? I probably have them on another openLuup install but not 100% which ones to copy over.
Zway Bridge
Error after device delete
PerHP
Zway Bridge
Device setup - organization strategy
PerHP
I've finally gotten the stuff to work together. Now - before I migrate all the vera devices, how do i use this? How does the variables NameDevices and CloneRooms work? (is there a manual or description of the plugin?) CloneRooms seems obvious, but is that the best way to go when I have more bridges? Set up rooms and names in Z-way? No rooms in z-way, and distribute them in openluup?
Zway Bridge
Changing device type for wall controller
Zway Bridge
Recreate Zway device in Openluup
Zway Bridge
Changing Device type from dimmer to Shutter
Zway Bridge
Child device undo failure
Hi AK, I must be missing something but I am having now some devices fail on the bridge due to them running out of battery. Upon battery replacement, they function properly on z-way-server but the failure remains over the bridge. The failure shows up on the parent device and it says that a specific command class has failed. Looking at the return API json, it should not return any command class level failure however so I am not sure where the bridge gets its failed state from... edit: Nevermind, I figured it out. It is a gap in data alignment between the different z-way APIs. The zwave and JS API got the update that the device recovered but not the smarthome API. Pausing and restarting the zwave app on z-way fixed it.
Zway Bridge
All Z-way devices "disabled" attribute is set to 1
K
Zway Bridge
So I started experimenting by moving some of my wallplugs and power switch zwave devices over from VeraPlus to Z-Way. In Z-Way this results in different elements for switching, Watts and kWh. Some even have Volts which I never saw on Vera. But using the Z-Way plugin in openLuup only the Switch element is visible and all other elements of the zwave node are not. I don't really know to much about Z-Way or the plugin, but am trying to learn on the run. Maybe someone can give me some pointers what and where to look for to solve this?
Zway Bridge
z-way with home assistant
Just wanted to point out and start the topic of the following: We are working on a project that will allow to use Z-Way library as the core of Z-Wave in Home Assistant. First releases will be around June/July I believe Additionally there are ways to support Z-Way from HAss via HTTP requests. This is a community project and we have no deep knowledge about it. С уважением, Полторак Сергей Z-Wave.Me https://community.home-assistant.io/t/official-z-way-integration-request/186710/27
Zway Bridge
Scheduled Pinned Locked Moved Zway Bridge
56 Posts 9 Posters 29.1k Views 10 Watching
  • J Offline
    J Offline
    JMK
    Done, version was v20.4.5 - did you typo?
      Yes, I did. So you have the latest openLuup and ZWay plugin now.
      You need to login in to your ZWay system through the plugin. If you go to the ZWay device control panel (by clicking on its icon on the Devices page) you will find the Actions menu (in blue) and there, right at the top, should be the login action. You need to enter your ZWay system admin username and password and then press the blue Login button.
      Returning to the devices page, you should see that the ZWay device is suggesting an openLuup reload. Do that.
      • J Offline
        J Offline
        JMK
        It worked...at last.Thanks for your patience.
          #30
          No, this is all my fault. The original ZWay plugin was prototyped four years ago, but in the last six months , with the way Vera was going, we ( @rafale77, @DesT, and some others) had a bit of a push to revive it and make it really functional. In the process, of course, documentation was not done.
          My fault, too, that when you said
          @JMK said in Help with Z-Way plugin:
          ...I assumed that it had all gone according to plan.
          So now you see your Fibaro switch, and it works...?
          • J Offline
            J Offline
            JMK
            Yes, I can see the Fibaro switch and I am able to toggle it. The reason I am going through all this is I also have just about had enough of Vera. I had small configurations (10-15 devices) at two locations that had worked flawlessly for 6 years on Vera3s when it looked like support for the Vera3 would end because of EOL I decided to migrate to VeraPlus. Big mistake. Devices dropping offline, scenes behaving strangely (triggering when they shouldn't, not triggering when they should). At the remote location I had to spend over $200 dollars to replace devices that had worked perfectly on the Vera3, and so on...
            Because I cannot afford to loose the automation here locally I am transferring one device at a time from the VeraPlus to the openLuup system - that's my plan anyway.
              ArcherS
              I updated my Z-way plugin to the latest Maser version (v20.4.5). In order to get the plugin to get updated I had to delete the existing Z-way plugin and start over. I had a really old v18.7.16, however it was working ok. I am on OpenLuup20.5.6, so that should be ok.
              I now have the latest version of the Z-way plugin, but I need to change IP from the default 127.0.0.1 to the right one (192.168.1.xx), on which my Z-way is running (not the same as my OpenLuup). However when I try to change IP via the "Variables" tab it does not stick, it reverts back to 127.0.0.1 after Luup reload. I have tried both via AltUI and via the OpenLuup (unsure where I should do this) but get no result either way.
              //ArcherS
                #33
                Yes. You should not be using the variable to set the IP address, but, instead, the device attribute named ip.
                (The variable you were, I assume, trying to change is an AltUI Display variable, which reflects the IP actually assigned.)
                  ArcherS
                  Thank's for a really quick reply! That indeed did the trick, I knew it was something easy I missed.
                  Now I just need to go through my Reactors and re-map my z-way devices. Not too much work.
                  //ArcherS
                  • J Offline
                    J Offline
                    JMK
                    I had a disaster yesterday - my Raspberry Pi SD died and looking at it i think it may have been a Sandisk fake, the labeling and fonts just do not look right. Anyway, I had to re-install Z-Way, openLuup... and this time I decided to put cmh-ludl in etc rather than in my home directory. I noticed that in the manual it says "be careful with permissions". So what are the 'correct' permissions? As you can see I am not too familiar with Linux 🙂
                    • J Offline
                      J Offline
                      JMK
                      Sorry more... I also notice that when I execute openLuup_reload I get these messages...
                      mkdir: cannot create directory ‘/www’: Permission denied
                      rm: cannot remove '/www/altui/altui*': No such file or directory
                        I don't know what they should be but 755 would be a good place to start.
                        How good are you with Linux? ls -l will show you the current user / group ownership. No idea what user Z-way will run as but you can
                        chmod 777 -R /www is pretty much bound to work but has some possibly nasty security impacts. I doubt it's a huge issue here though
                        • J JMK
                          I originally suggest that location, in order to mimic Vera's files structure, but during openLuup's evolution it developed a virtual storage system and file aliases which means that it only needs to access folders within its own home directory tree. Even things like /www/cgi/ and /www/cgi-bin/cmh/ are handled that way.
                          So, really, I can't think of a good reason to put it in /etc/, indeed, I think you've found a good reason not to.
                          I think you'll find those two error messages come from AltUI, certainly the second one which I know to be benign.
                          • J Offline
                            J Offline
                            JMK
                            Settled for 0755, seems to be OK. Thanks everyone.
                              wrote on last edited by PerH
                              #40
                              Can't seem to get any devices in openluup!
                              Everything OK in Z-Way:
                              4 devices working perfectly:
                              Openluup versions:
                              Attributes:
                              Log:
                              2020-11-04 13:49:44.303   openLuup.scheduler:: [197] Z-Way device startup
                              2020-11-04 13:49:44.303   luup_log:197: ZWay: v20.4.5
                              2020-11-04 13:49:44.336   luup_log:197: ZWay: HomeId: c84d9ef4
                              2020-11-04 13:49:44.336   luup.variable_set:: 197.urn:upnp-org:serviceId:altui1.DisplayLine1 was: 0 vDevs, 0 zNodes now:  #hooks:0
                              2020-11-04 13:49:44.336   luup.register_handler:: global_function_name=HTTP_Z-Way_197, request=z197
                              2020-11-04 13:49:44.361   luup.set_failure:: status = 0
                              2020-11-04 13:49:44.361   luup.variable_set:: 197.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
                              2020-11-04 13:49:44.361   luup.variable_set:: 197.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
                              2020-11-04 13:49:44.394   luup.variable_set:: 197.urn:upnp-org:serviceId:altui1.DisplayLine1 was:  now: 0 vDevs, 0 zNodes #hooks:0
                              2020-11-04 13:49:44.394   luup_log:197: ZWay: Asynchronous polling
                              2020-11-04 13:49:44.394   luup.set_failure:: status = 0
                              2020-11-04 13:49:44.394   luup.variable_set:: 197.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0
                              2020-11-04 13:49:44.394   luup.variable_set:: 197.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0
                              2020-11-04 13:49:44.395   openLuup.scheduler:: [197] Z-Way device startup completed: status=true, msg=OK, name=L_ZWay2
                              result:
                              Any ideas? 🙂
                                #41
                                zway username and password set in the plugin variables?
                                  Where?
                                  I used "Actions" - login, and set "no expire" on the emerging connection in z-way..?
                                  • PerHP PerH
                                    Where?
                                    @PerH
                                    Go to the openLuup console from your openLuup device you can see the access to the console interface:
                                    Then go into devices/z-way bridge and under actions, login
                                      Done, no difference..
                                      Same entrys in the startuplog as before.. ?
                                      Noticed that "file not found: cgi/zway_cgi.lua" comes up when i try the "Configure ZWay child devices" button, is that a clue of something?
                                        that's not good. You need that file. seems like your plugin is not completely installed.
                                        see that you have the files in this repo all installed:
                                        GitHub - akbooer/Z-Way: Zway plugin for openLuup
                                        Zway plugin for openLuup . Contribute to akbooer/Z-Way development by creating an account on GitHub.
                                        the cgi file under the /cgi folder needs to be in the /cgi folder in openLuup.
                                          Fixed. all files are in place, still no devices..
                                          This is all that shows up when i try the "Configure ZWay child devices" :
                                            165.5k
