  2. Hardware
  3. Z-Wave.me
  4. Docker container for Z-Way
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
PerHP
Z-Wave.me
37 Posts 8 Posters 21.3k Views 8 Watching
    Oooh, I now get to the local smarthome web page.
    I switched to "host" for the network mode.
    Not sure whether the Zwave stuff actually works...
      ...apparently not:
      12:34   Cannot start Z-Wave binding: Error: Invalid port
      12:34   Cannot instantiate module: HomeKitGate: Error: Failed to announce DNS record
      Not sure how to fix this? Clearly need to map to the UZB somehow?
      Also keen to learn more about the HomeHitGate...
        Are you using my docker-compose? Don't know anything about synology, but I always use the /dev/serial/by-ID... designation, as it doesn't shift addresses.. But you can have a simpler address internally (the one after the ":" ).
        Host works, but you should be able to just forward 8083 as well? if something else also uses it on the host, you can change it on the outside (before the ":")..
        I think the log looks fine, don't know anything about homekitgate though..
        Mabye you can post your docker-compose?
          Thanks, I've got this a step further by running the docker in privileged mode which allows mapping of the /dev directory, so that it does now find the UZB. This is running under Synology DSM v6, which is not the latest, but I understand that under version 7 it doesn't allow mapping of device ports at all. (This is a bit of a downer for people trying to use a UPS, AFAIK, which was the next thing I was wanting to add.)
          I'm not using docker-compose at all, just the native Synology Docker UI and/or editing the config.json directly.
          Anyway, one step more along the way. Next is to try add a Zwave device. The only reason I'm doing this is to move my two final Zwave devices (power meter readers) off of Vera , because I can find no equivalent devices which use WiFi.
          Thanks again for the response.
            Now seeing:
            sh: 1: ip: not found
            I think this happens when trying to include a device, which eventually fails with timeout.
              That one is OK, it's related to the UI in some way, and not the stick..
              Very strange that you have contact to the stick, but can't include? that part usually works flawlessly, I don't use the expert panel for that though, as the other UI has a naming wizard for the units..
                OK, I’ll try again!
                  #33
                  @PerH
                  ...still not working, just timing out on any include.
                  Are there any other parameters in the config that need changing? I see an id parameter – is that relevant? Or maybe not using the right frequency band (I am in the UK) ?
                  How is the licence key handled in the stick? I recall having to buy a licence separately??
                    Ok, so what firmware do you have? You've used this stick before?
                    The firmware stuff is a bit of a mess, look at this thread..
                    As I discovered; There is a Bridge firmware for using the stick without z-way, and a regular one for Z-Way. Mabye you have the bridge one?
                    Don't think you have area troubles, EU is part of the most common firmware..
                    • PerHP PerH
                      You could see if mine works for you?
                      perhu/z-way-server-3-2-1 - Docker Image
                      Works great here, there is an updated docker-compose in the description on dockerhub. 🙂
                      RHCPNG
                      @PerH Does your docker image support Socat? And, if so, is the configuration persistent after a container update?
                        wrote on last edited by PerH
                        #36
                        Its been a while since i've used this now, I've moved to Z-WaveJS..
                        Socat - so you have a remote connection to your z-stick? Should work fine with this contatiner, just set it up in the docker-compose file.
                        That said, I would ask on the z-way forum, you may find a more current z-way version in a newer container..
                        All settings should be persistent if volumes are set up correctly.
                        R 1 Reply Last reply
                        • PerHP PerH
                          RHCPNG
                          @PerH said in Docker container for Z-Way:
                          I don't have a remote connection yet, I'm preparing for the migration from Vera to Z-way. I wanted to nuke the Vera and use it as a central hub for my Z-way stick.
                          From what I've read, Socat will not work in combination with docker. The Ser2net/ Socat solution is giving me a headache with the preparation alone. It is difficult with docker, so it seems, unless you create a docker specifically with Socat in it. But creating docker images is not a skill I possess (yet).
                          Unlike others in this thread, I'm a fan of docker containers. (Easier to maintain, troubleshoot and keep up-to-date). But Socat is a show stopper for now.
                          I think I'll ditch the Vera Edge and Z-way docker. I'm looking at using a Raspberry Pi with USB/IP (can't easily install this on the Vera) now instead of Ser2net/Socat and running the Z-way addon for HA.
                            317
                            151.0k
