  3. Zway Bridge
  4. Z-way token Expiration
full devices reset
@akbooer Since a couple of weeks/months, we are in the process to redo 5 rooms @ home (kids are moving from room to another room) and of course, I would need to redo a bunch of device name and room name in Zway.. Is there an easy way to tell openLuup to completely start over fresh without having to delete/rename them one by one in openLuup ?
Zway Bridge
Help with Z-Way plugin
I hope this is the correct forum – apologies if not! I have a Raspberry Pi3 with a Razberry Z-Wave card installed. I have installed the Z-Way software and have successfully included a Fibaro Z-Wave switch on the Z-Wave network. I can toggle the switch on and off successfully from my laptop through port 8083 of the Raspberry Pi3. On the same Raspberry Pi3 I have installed openLuup on which I have installed the Z-Way plugin. I can access this through port 3480 on the Raspberry Pi3 from my laptop. Here is where I have come to a dead stop. How do I get access to the Fibaro Z-Wave switch from the openLuup application? I can find no documentation that tells me specifically how to do this. Any help would be greatly appreciated. _John.
Zway Bridge
openLuup Z-Way bridge: Version Log
Master Branch: 2020 Release 4.5 Roll-up of recent changes in development branch.
Zway Bridge
Fibaro Wall plug power metering
PerHP
I have an odd issue which seems to be only for Fibaro wall plugs. They come in to Z-Way with two "electric meter" entrys, one "Power" meter and a couple of alarm entrys. In addition to the switch that is. One of the "electric meters" is KWh and the other one is seemingly Watts, but it stays at 0/-1w. The "Power" meter shows the Watts used right now. When these come into openluup, the wrong electric meter is selected for displaying the Watts, is there any way to manipulate which one openLuup uses? I see that the sub channel for power also is transferred, but it isn't in the data Veraflux is transmitting to my influxdb.. Haven't used the watts reading for anything before now, now i want to estimate when my dryer is done based on power usage.
Zway Bridge
Renaming device name...
@akbooer What's the "logic" behind zway plugin about renaming ? Are you always renaming when starting openLuup ?
Zway Bridge
Fibaro TRV on ZWay/OpenLuup?
Having some trouble getting the Fibaro TRV device working with the ZWay bridge. The device works in the ZWay (Zwave.Me) Smart Home GUI, and creates a number of devices in OpenLuup, some of which appear to have the right variables in it. Changing the XML and JSON files makes no difference. I also tried creating a separate child device for Parameter 67 (using the gui for the ZWay bridge, see below), and setting the XML/JSON types for that device (like I've havd to do for a few other devices). This results in a device that correctly displays the TRV setpoint, but chaning the setpoint in the OpenLuup gui does not result in anything being transmitted to/by ZWay. 20490 49-0 D_ComboDevice1.xml zNode #49-0 49-0-113-8-12-A 49-0-113-8-13-A 49-0-113-8-14-A 49-0-113-8-15-A 49-0-113-9-3-A 49-0-64 49-0-67-1 20491 49-1 D_ComboDevice1.xml zNode #49-1 49-1-113-8-12-A 49-1-113-8-13-A 49-1-113-8-14-A 49-1-113-8-15-A 49-1-113-9-3-A 49-1-64 25031 49-1-67-1 D_Heater1.xml Radiator Bedroom 20492 49-2 D_ComboDevice1.xml multi #49-2 49-2-113-8-10-A 49-2-113-8-11-A 25030 49-2-49-1 D_TemperatureSensor1.xml Radiator Bedroom
Zway Bridge
@akbooer, I just woke up to a z-way bridge token expiration again forcing me to login again and reload openluup. It appears to happen once a week. It doesn't appear that the auto renewal of the token is working?
Zway Bridge
Why Migrate to Z-way from vera and how?
I expect this document to be dynamic based on inputs from people who try but did not want to completely rewrite it here: https://github.com/rafale77/Z-Way/blob/master/README.md
Zway Bridge
XMLs & jsons without vera
P
Nearly there with the migration .. Is it ok to use older device files or do they get updated from time to time? Now that a fresh openLuup is up and running and connected to Zway where's the best place to source device files without vera? I probably have them on another openLuup install but not 100% which ones to copy over.
Zway Bridge
Error after device delete
PerHP
Zway Bridge
Device setup - organization strategy
PerHP
I've finally gotten the stuff to work together. Now - before I migrate all the vera devices, how do i use this? How does the variables NameDevices and CloneRooms work? (is there a manual or description of the plugin?) CloneRooms seems obvious, but is that the best way to go when I have more bridges? Set up rooms and names in Z-way? No rooms in z-way, and distribute them in openluup?
Zway Bridge
Changing device type for wall controller
Zway Bridge
Recreate Zway device in Openluup
Zway Bridge
Changing Device type from dimmer to Shutter
Zway Bridge
Child device undo failure
Hi AK, I must be missing something but I am having now some devices fail on the bridge due to them running out of battery. Upon battery replacement, they function properly on z-way-server but the failure remains over the bridge. The failure shows up on the parent device and it says that a specific command class has failed. Looking at the return API json, it should not return any command class level failure however so I am not sure where the bridge gets its failed state from... edit: Nevermind, I figured it out. It is a gap in data alignment between the different z-way APIs. The zwave and JS API got the update that the device recovered but not the smarthome API. Pausing and restarting the zwave app on z-way fixed it.
Zway Bridge
All Z-way devices "disabled" attribute is set to 1
K
Zway Bridge
So I started experimenting by moving some of my wallplugs and power switch zwave devices over from VeraPlus to Z-Way. In Z-Way this results in different elements for switching, Watts and kWh. Some even have Volts which I never saw on Vera. But using the Z-Way plugin in openLuup only the Switch element is visible and all other elements of the zwave node are not. I don't really know to much about Z-Way or the plugin, but am trying to learn on the run. Maybe someone can give me some pointers what and where to look for to solve this?
Zway Bridge
z-way with home assistant
Just wanted to point out and start the topic of the following: We are working on a project that will allow to use Z-Way library as the core of Z-Wave in Home Assistant. First releases will be around June/July I believe Additionally there are ways to support Z-Way from HAss via HTTP requests. This is a community project and we have no deep knowledge about it. С уважением, Полторак Сергей Z-Wave.Me https://community.home-assistant.io/t/official-z-way-integration-request/186710/27
Zway Bridge
Scheduled Pinned Locked Moved Zway Bridge
38 Posts 5 Posters 18.4k Views 5 Watching
    It sticked for over a month, now i'm suddenly thrown out again.. @akbooer: I see in the log that the bridge knows its not logged in (says so in the reply to commands), could you set a variable for this, so reactor can be set up to notify me when this happens?
    Seems to be an issue on the z-way side..
      That's very weird. Mine has not expired in 8 months. Is the token still in the bridge variable? I don't believe z-way resets it (based on my own experience)
      No kidding. See my screen as of today:
        I'm pretty sure it was there, and there was still "not logged in" in the log.. two days since last luup reload (added some sensors)..
        • PerHP PerH
          @perh
          I’ll look at setting a variable to flag this condition, but like @rafale77 i haven’t seen this happen myself.
            Further to your request for a variable flag, there already is one, of course...
            ...if DisplayLine1 shows "Login required", then it's lost the token.
              I'm pretty sure it didn't, and "commfailure" was zero as well? Thats why I went to the openluup log to find out what had happened.
              I'll see if i can reproduce this state..
                Confirmed. If I remove the active session for AltUI in Z-Way, i get this situation.
                Openluup log:
                2021-01-13 16:51:01.685   luup_log:198: ZWay: http://127.0.0.1:8083/ZAutomation/api/v1/devices
                2021-01-13 16:51:01.686   luup_log:198: ZWay: Not logged in
                2021-01-13 16:51:01.686   luup_log:198: ZWay ASYNC callback status: 401, #data: 13
                2021-01-13 16:51:02.722   luup_log:198: ZWay: http://127.0.0.1:8083/ZAutomation/api/v1/devices
                2021-01-13 16:51:02.722   luup_log:198: ZWay: Not logged in
                2021-01-13 16:51:02.722   luup_log:198: ZWay ASYNC callback status: 401, #data: 13
                No visible "not logged in" in GUI, and commfailure is 0?
                  Yes. It’s only set at startup.
                    Ok, and to update DisplayLine1 when the openluup log is told "not logged in" should be an easy fix? I'll see if i can do it myself. 🙂
                      @akbooer, Is this the correct way to get DisplayLine updated if 401 is replied for a command?
                      Line 1761 in L_Zway2.lua:
                        function _G.ZWay_async_callback (status, response)
                          local delay = POLLRATE
                          debug ("aync callback size: " .. #(response or empty))
                          if status == 200 and response then
                            local d = json.decode (response)
                            local vDevs = d and d.data and d.data.devices
                            if vDevs then
                              updateChildren (vDevs) end
                              --        delay = POLL_MINIMUM end                    -- yes, ask for another one soon...
                              --        init = ''                                   -- ... without initialising data version
                          elseif status == 401 then
                      	setVar ("DisplayLine1", 'Login required', SID.AltUI)
                          else
                            luup.log (log: format (status or '?', #(response or '')))
                          luup.call_delay ("ZWay_async_request", delay, '')    -- schedule next request
                        There's a few problems introduced here:
                        • there's also a synchronous request which perhaps need to be changed as well
                        • you've lost the output to the log in the case of 401
                        • it doesn't change the CommFailure variable or device status
                        Although I suggested it as a quick-fix, I don't think that useing the DisplayVariable is a particularly good way of flagging the error to a scene trigger (CommFailure would perhaps be more appropriate.)
                        Is this still an ongoing issue for you (ie. are you losing the credentials on a regular basis?)
                          No, haven't seen it since i mentioned it here.
                          I agree that commfailure should be set, and as long as something can tell me why shit stopped working without me going into AltUI (cursing), i'm happy. 🙂
                          If this is a viable way to do it, i'll use commfailure instead, and copy the log() line to the elseif and to the sync function.
                          The reason why the line drops should offcourse be addressed, but I think this is an important feature nevertheless, as there might be bugs in z-way and it seems to take a while between updates there..
                          I don't think i've had a single luup reload by the system since I was running Vera.. 🙂
                          • PerHP PerH
                            @perh said in Z-way token Expiration:
                            No, it’s not sufficient to do that, since device status and last failure time will not be set.
                            You need to use luup.set_failure()
                            http://wiki.micasaverde.com/index.php/Luup_Lua_extensions#function:_set_failure
                            There need to be a few more changes to the ZWay module in the plugin too.
                            I’ll post a new version shortly, so that it’ll be in the baseline.
                              ZWay development branch v21.1.19 has a fix.
                              As well as setting CommFailure, it also sets CommFailureTime, and the internal device status, which turns the plugin's device banner red on both AltUI and the openLuup console interfaces.
                              As I've said many times, this whole plugin was just a prototype and it seriously need rewriting to improve maintainability... but, nevertheless, it does work quite well.
                                wrote on last edited by PerH
                                #31
                                It definately does. (work well, that is) Thanks!
                                  Token lost again today..
                                  The z-way-server.log seems to be about z-wave communication only, wonder if I can find traces of wtf is happening with the token somewhere as well?
                                    Is this exactly 7 days after it was refreshed?
                                      nope. 9 days..
                                      • P Offline
                                        P Offline
                                        powisquare
                                        Updated openLuup to v. 21.6.8 yesterday. I notice the z-way bridge has lost connection. and requires login. When I go to device/actions there is no way to enter credentials - only a login button.
                                          Ooh, good spot! NO idea where that's gone. Will take a look.
                                            158.2k
