  3. Zway Bridge
  4. Help with Z-Way plugin
full devices reset
@akbooer Since a couple of weeks/months, we are in the process to redo 5 rooms @ home (kids are moving from room to another room) and of course, I would need to redo a bunch of device name and room name in Zway.. Is there an easy way to tell openLuup to completely start over fresh without having to delete/rename them one by one in openLuup ?
Zway Bridge
I hope this is the correct forum – apologies if not! I have a Raspberry Pi3 with a Razberry Z-Wave card installed. I have installed the Z-Way software and have successfully included a Fibaro Z-Wave switch on the Z-Wave network. I can toggle the switch on and off successfully from my laptop through port 8083 of the Raspberry Pi3. On the same Raspberry Pi3 I have installed openLuup on which I have installed the Z-Way plugin. I can access this through port 3480 on the Raspberry Pi3 from my laptop. Here is where I have come to a dead stop. How do I get access to the Fibaro Z-Wave switch from the openLuup application? I can find no documentation that tells me specifically how to do this. Any help would be greatly appreciated. _John.
Zway Bridge
openLuup Z-Way bridge: Version Log
Master Branch: 2020 Release 4.5 Roll-up of recent changes in development branch.
Zway Bridge
Fibaro Wall plug power metering
PerHP
I have an odd issue which seems to be only for Fibaro wall plugs. They come in to Z-Way with two "electric meter" entrys, one "Power" meter and a couple of alarm entrys. In addition to the switch that is. One of the "electric meters" is KWh and the other one is seemingly Watts, but it stays at 0/-1w. The "Power" meter shows the Watts used right now. When these come into openluup, the wrong electric meter is selected for displaying the Watts, is there any way to manipulate which one openLuup uses? I see that the sub channel for power also is transferred, but it isn't in the data Veraflux is transmitting to my influxdb.. Haven't used the watts reading for anything before now, now i want to estimate when my dryer is done based on power usage.
Zway Bridge
Renaming device name...
@akbooer What's the "logic" behind zway plugin about renaming ? Are you always renaming when starting openLuup ?
Zway Bridge
Fibaro TRV on ZWay/OpenLuup?
Having some trouble getting the Fibaro TRV device working with the ZWay bridge. The device works in the ZWay (Zwave.Me) Smart Home GUI, and creates a number of devices in OpenLuup, some of which appear to have the right variables in it. Changing the XML and JSON files makes no difference. I also tried creating a separate child device for Parameter 67 (using the gui for the ZWay bridge, see below), and setting the XML/JSON types for that device (like I've havd to do for a few other devices). This results in a device that correctly displays the TRV setpoint, but chaning the setpoint in the OpenLuup gui does not result in anything being transmitted to/by ZWay. 20490 49-0 D_ComboDevice1.xml zNode #49-0 49-0-113-8-12-A 49-0-113-8-13-A 49-0-113-8-14-A 49-0-113-8-15-A 49-0-113-9-3-A 49-0-64 49-0-67-1 20491 49-1 D_ComboDevice1.xml zNode #49-1 49-1-113-8-12-A 49-1-113-8-13-A 49-1-113-8-14-A 49-1-113-8-15-A 49-1-113-9-3-A 49-1-64 25031 49-1-67-1 D_Heater1.xml Radiator Bedroom 20492 49-2 D_ComboDevice1.xml multi #49-2 49-2-113-8-10-A 49-2-113-8-11-A 25030 49-2-49-1 D_TemperatureSensor1.xml Radiator Bedroom
Zway Bridge
Z-way token Expiration
@akbooer, I just woke up to a z-way bridge token expiration again forcing me to login again and reload openluup. It appears to happen once a week. It doesn't appear that the auto renewal of the token is working?
Zway Bridge
Why Migrate to Z-way from vera and how?
I expect this document to be dynamic based on inputs from people who try but did not want to completely rewrite it here: https://github.com/rafale77/Z-Way/blob/master/README.md
Zway Bridge
XMLs & jsons without vera
P
Nearly there with the migration .. Is it ok to use older device files or do they get updated from time to time? Now that a fresh openLuup is up and running and connected to Zway where's the best place to source device files without vera? I probably have them on another openLuup install but not 100% which ones to copy over.
Zway Bridge
Error after device delete
PerHP
Zway Bridge
Device setup - organization strategy
PerHP
I've finally gotten the stuff to work together. Now - before I migrate all the vera devices, how do i use this? How does the variables NameDevices and CloneRooms work? (is there a manual or description of the plugin?) CloneRooms seems obvious, but is that the best way to go when I have more bridges? Set up rooms and names in Z-way? No rooms in z-way, and distribute them in openluup?
Zway Bridge
Changing device type for wall controller
Zway Bridge
Recreate Zway device in Openluup
Zway Bridge
Changing Device type from dimmer to Shutter
Zway Bridge
Child device undo failure
Hi AK, I must be missing something but I am having now some devices fail on the bridge due to them running out of battery. Upon battery replacement, they function properly on z-way-server but the failure remains over the bridge. The failure shows up on the parent device and it says that a specific command class has failed. Looking at the return API json, it should not return any command class level failure however so I am not sure where the bridge gets its failed state from... edit: Nevermind, I figured it out. It is a gap in data alignment between the different z-way APIs. The zwave and JS API got the update that the device recovered but not the smarthome API. Pausing and restarting the zwave app on z-way fixed it.
Zway Bridge
All Z-way devices "disabled" attribute is set to 1
K
Zway Bridge
So I started experimenting by moving some of my wallplugs and power switch zwave devices over from VeraPlus to Z-Way. In Z-Way this results in different elements for switching, Watts and kWh. Some even have Volts which I never saw on Vera. But using the Z-Way plugin in openLuup only the Switch element is visible and all other elements of the zwave node are not. I don't really know to much about Z-Way or the plugin, but am trying to learn on the run. Maybe someone can give me some pointers what and where to look for to solve this?
Zway Bridge
z-way with home assistant
Just wanted to point out and start the topic of the following: We are working on a project that will allow to use Z-Way library as the core of Z-Wave in Home Assistant. First releases will be around June/July I believe Additionally there are ways to support Z-Way from HAss via HTTP requests. This is a community project and we have no deep knowledge about it. С уважением, Полторак Сергей Z-Wave.Me https://community.home-assistant.io/t/official-z-way-integration-request/186710/27
Zway Bridge
Scheduled Pinned Locked Moved Zway Bridge
56 Posts 9 Posters 29.1k Views 10 Watching
    No, neither, I think. I am talking about the openLuup ZWay plugin device itself. The image you showed of the empty actions tag has the device attributes greyed out in the background. From there I see that you have I_ZWay.xml whereas it should be I_ZWay2.xml. So I am worried about the version of its other files too.
    You can just manually change this attribute to the correct one and restart to see if that fixes things, but the problem may be deeper than that. What version does it say it is?
    • J Offline
      J Offline
      JMK
      Changed the implementation file..
      9a688f53-f38e-4135-ba4a-e1a2dd21c728-image.png Here is the version...ba048e59-6aea-4282-9c00-12df850c802e-image.png
      • J Offline
        J Offline
        JMK
        I could not see any Z-Wave devices after changing the implementation file.
          The version number is very old - totally the wrong thing. Go to the AltUI > More > App Store page, find the ZWay plugin there, and click on the Alt button to download the latest. It should be version 20.5.4b (GitHub.master).
          • J Offline
            J Offline
            JMK
            Did as you said, now no version number...79c2a084-7096-480f-b78b-826e17fd55f4-image.png
            I can't help feeling there is something fundamentally wrong here but I have insufficient knowledge to identify what it is. 😕
              Did you you reload the luup engine after changing the implementation file to I_Zway2.xml?
              Did you check that the file exists in the /etc/cmh-ludl folder?
                I see this has a new device number, so if device #5 is still there, then delete it.
                I'd like to see the startup log and the openLuup console page Scheduler > Plugins
                It really, really, shouldn't be as much of a pain as this. I don't have a clear picture of quite how things went wrong in the first place.
                  @rafale77 said in Help with Z-Way plugin:
                  Actually, it won't be there. Only L_Zway2.lua is a physical file. All its other device files are part of openLuup's virtual storage system.
                    Ohh yes you are right. Sorry about this. I was thinking of the lua file indeed.
                    • J Offline
                      J Offline
                      JMK
                      Here is a suggestion. If you can tell me how to completely un-install the openLuup software so that you can give me instructions on how to install it from scratch properly, maybe that would be a way forward?
                        No, the problem is not openLuup, and openLuup is not like Vera. You simply don’t need to tear everything down and start again.
                        • verify that you have the latest openLuup system from the development branch. The Plugin page should show 20.5.3b, or thereabouts.
                        • delete any ZWay plugin device
                        • check there are no devices lurking in room 101 (delete them if they are)
                        • install ZWay once again from the master branch, from the (Alt) App Store.
                        • send me a Startup log, so that I have something to go on.
                        • don’t forget to login to the ZWay plugin using the Login action of the plugin.
                        • J Offline
                          J Offline
                          JMK
                          1. I have 19.12.27
                          2. Deleted Razberry device, deleted Z-way device
                          3. Cannot see any "Room 101"
                          4. Installed ZWay
                          5. ???Where is the Startup log???
                            6.???Where is the "Login action of the plugin"???
                            Sorry if I am being thick.
                            #24
                            OK, so first you need the latest openLuup version. Simply go to the Plugins page, type development into the update box and click the update button. Wait for it to restart. You should be on 20.5.3b of openLuup.
                            Let's do that step first.
                            • J Offline
                              J Offline
                              JMK
                              Done, sucessful
                                #26
                                Excellent! From the AltUI > More > App Store page, install the master version of the ZWay plugin. It should be v20.5.4. v20.4.5.
                                • J Offline
                                  J Offline
                                  JMK
                                  Done, version was v20.4.5 - did you typo?
                                    Yes, I did. So you have the latest openLuup and ZWay plugin now.
                                    You need to login in to your ZWay system through the plugin. If you go to the ZWay device control panel (by clicking on its icon on the Devices page) you will find the Actions menu (in blue) and there, right at the top, should be the login action. You need to enter your ZWay system admin username and password and then press the blue Login button.
                                    Returning to the devices page, you should see that the ZWay device is suggesting an openLuup reload. Do that.
                                    • J Offline
                                      J Offline
                                      JMK
                                      It worked...at last.Thanks for your patience.
                                        #30
                                        No, this is all my fault. The original ZWay plugin was prototyped four years ago, but in the last six months , with the way Vera was going, we ( @rafale77, @DesT, and some others) had a bit of a push to revive it and make it really functional. In the process, of course, documentation was not done.
                                        My fault, too, that when you said
                                        @JMK said in Help with Z-Way plugin:
                                        ...I assumed that it had all gone according to plan.
                                        So now you see your Fibaro switch, and it works...?
                                        • J Offline
                                          J Offline
                                          JMK
                                          Yes, I can see the Fibaro switch and I am able to toggle it. The reason I am going through all this is I also have just about had enough of Vera. I had small configurations (10-15 devices) at two locations that had worked flawlessly for 6 years on Vera3s when it looked like support for the Vera3 would end because of EOL I decided to migrate to VeraPlus. Big mistake. Devices dropping offline, scenes behaving strangely (triggering when they shouldn't, not triggering when they should). At the remote location I had to spend over $200 dollars to replace devices that had worked perfectly on the Vera3, and so on...
                                          Because I cannot afford to loose the automation here locally I am transferring one device at a time from the VeraPlus to the openLuup system - that's my plan anyway.
                                            165.5k
