  2. Hardware
  3. Z-Wave.me
  4. logrotate for z-way-server
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
PerHP
Z-Wave.me
23 Posts 5 Posters 8.1k Views 5 Watching
  • DesTD Offline
    DesTD Offline
    DesT
    @PoltoS I think you need to check how you handle logging, if they need to kill -HUP the process, that's 'cause you lock the file instead of just appending at the end! 😉
      @DesT
      No it does not kill the server, it signals to the z-way-server that it needs to start a new log file.
      The vera runs an equivalent command with its log rotation by the way.
      @prophead said in logrotate for z-way-server:
      OT, could I use this make automated backups of my openluup user_data file?
      Hmm for this I would use a crontab. Can start another thread if you want or need.
      These are some examples:
      Rahul  /  Apr 25, 2025  /  Linux Commands
      Understanding Crontab in Linux with 20 Useful Examples
      20 Tips for running Jobs with crontabIn Linux. A Beginner’s Guide for understanding the Crontab configuration and scheduling Job to run.
      propheadP Offline
      propheadP Offline
      prophead
      @rafale77 i know how to use cron. how to get logrotate functionality to have 5 backups?
      • propheadP prophead
        @prophead
        I am just now getting to understand what you are trying to do...
        You can use the same script above and change the file to the openLuup user-data.json file and change the number "9" to "5".
        Also remove the "killall" line.
          Just to say that openLuup has a built-in CGI to accomplish this (files backed up to the cmh-ludl/backups/ folder in LZAP compressed form by default.) These may be used to directly restore an openLuup configuration. You could trigger the backup with a timed scene.
          The openLuup console Backup page shows the available backups...
          rafale77R propheadP 2 Replies Last reply
            @akbooer
            I really wanted to post the same thing earlier... but... it would be nice to have a "restore" function on this page to make the functionality whole...
            • propheadP Offline
              propheadP Offline
              prophead
              I use the backups manually. I want automated with rotation. Why hack lua to do this if its easy in os?
                The openLuup plugin has a SendToTrash action which internally uses a file retention manager which can limit the number of files in a folder to:
                • the most recent N
                • files younger than a certain number of days old
                • only certain file types
                Again, this can be run from a regularly scheduled scene. Files are temporarily moved to the Trash folder but may be permanently deleted by the EmptyTrash action of the openLuup plugin.
                The same procedure can be used to manage image files.
                I don't call this 'hacking Lua' 😉
                  propheadP Offline
                  propheadP Offline
                  prophead
                  @akbooer So I'm trying to do rotated backups the openLuup way, and expected backup to be an action. Apparently not. What is the best way to call a local cgi? luup.inet.wget(http://127.0.0.1/backup.cgi)?
                  • propheadP Offline
                    propheadP Offline
                    prophead
                    Can't seem to get the SendToTrash action to work either, heres my attempt:
                    luup.call_action ("openLuup","SendToTrash",{Folder="/etc/cmh-ludl/backup",MaxDays="",MaxFiles="10",FileTypes="lzap"},2)
                    I really wish you would put examples in your documentation.
                    the log files show luup_log:2: applying file retention policy... luup_log:2: ...finished applying file retention policy
                    but the files are still there.
                    Any help?
                      Yes, I would have expected that too... except that we are talking about a Vera feature here, which is used by the AltUI interface, so it has to be done this way to be compatible.
                      In this case, you need:
                      luup.inet.wget "/cgi-bin/cmh/backup.sh?"
                      HTH
                        Any help?
                        #22
                        Yes indeed, another appallingly badly documented feature.
                        In order to prevent an ill-advised programmer from wreaking havoc, absolute paths are not allowed. So you should use:
                        luup.call_action ("openLuup","SendToTrash",{Folder="backup",MaxDays="",MaxFiles="10",FileTypes="lzap"},2)
                        In addition, certain key folders are denied access, including
                        openLuup, cgi, cgi-bin, cmh, historian, whisper, files, icons, www
                        I will try to improve the documentation.
                        propheadP 1 Reply Last reply
                          propheadP Offline
                          propheadP Offline
                          prophead
                          @akbooer Thank you, that worked.
                            146.9k
