  3. Zway Bridge
  4. Z-way token Expiration
full devices reset
Zway Bridge
Help with Z-Way plugin
Zway Bridge
Zway Bridge
Zway Bridge
Renaming device name...
Zway Bridge
Fibaro TRV on ZWay/OpenLuup?
Zway Bridge
Zway Bridge
Zway Bridge
XMLs & jsons without vera
P
Zway Bridge
Error after device delete
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Zway Bridge
Child device undo failure
Zway Bridge
K
Zway Bridge
Zway Bridge
z-way with home assistant
Zway Bridge
38 Posts 5 Posters 18.0k Views 5 Watching
    Further to your request for a variable flag, there already is one, of course...
    ...if DisplayLine1 shows "Login required", then it's lost the token.
      I'm pretty sure it didn't, and "commfailure" was zero as well? Thats why I went to the openluup log to find out what had happened.
      I'll see if i can reproduce this state..
        Confirmed. If I remove the active session for AltUI in Z-Way, i get this situation.
        Openluup log:
        2021-01-13 16:51:01.685   luup_log:198: ZWay: http://127.0.0.1:8083/ZAutomation/api/v1/devices
        2021-01-13 16:51:01.686   luup_log:198: ZWay: Not logged in
        2021-01-13 16:51:01.686   luup_log:198: ZWay ASYNC callback status: 401, #data: 13
        2021-01-13 16:51:02.722   luup_log:198: ZWay: http://127.0.0.1:8083/ZAutomation/api/v1/devices
        2021-01-13 16:51:02.722   luup_log:198: ZWay: Not logged in
        2021-01-13 16:51:02.722   luup_log:198: ZWay ASYNC callback status: 401, #data: 13
        No visible "not logged in" in GUI, and commfailure is 0?
          Yes. It’s only set at startup.
            Ok, and to update DisplayLine1 when the openluup log is told "not logged in" should be an easy fix? I'll see if i can do it myself. 🙂
              @akbooer, Is this the correct way to get DisplayLine updated if 401 is replied for a command?
              Line 1761 in L_Zway2.lua:
                function _G.ZWay_async_callback (status, response)
                  local delay = POLLRATE
                  debug ("aync callback size: " .. #(response or empty))
                  if status == 200 and response then
                    local d = json.decode (response)
                    local vDevs = d and d.data and d.data.devices
                    if vDevs then
                      updateChildren (vDevs) end
                      --        delay = POLL_MINIMUM end                    -- yes, ask for another one soon...
                      --        init = ''                                   -- ... without initialising data version
                  elseif status == 401 then
              	setVar ("DisplayLine1", 'Login required', SID.AltUI)
                  else
                    luup.log (log: format (status or '?', #(response or '')))
                  luup.call_delay ("ZWay_async_request", delay, '')    -- schedule next request
                There's a few problems introduced here:
                • there's also a synchronous request which perhaps need to be changed as well
                • you've lost the output to the log in the case of 401
                • it doesn't change the CommFailure variable or device status
                Although I suggested it as a quick-fix, I don't think that useing the DisplayVariable is a particularly good way of flagging the error to a scene trigger (CommFailure would perhaps be more appropriate.)
                Is this still an ongoing issue for you (ie. are you losing the credentials on a regular basis?)
                  No, haven't seen it since i mentioned it here.
                  I agree that commfailure should be set, and as long as something can tell me why shit stopped working without me going into AltUI (cursing), i'm happy. 🙂
                  If this is a viable way to do it, i'll use commfailure instead, and copy the log() line to the elseif and to the sync function.
                  The reason why the line drops should offcourse be addressed, but I think this is an important feature nevertheless, as there might be bugs in z-way and it seems to take a while between updates there..
                  I don't think i've had a single luup reload by the system since I was running Vera.. 🙂
                  • PerHP PerH
                    @perh said in Z-way token Expiration:
                    No, it’s not sufficient to do that, since device status and last failure time will not be set.
                    You need to use luup.set_failure()
                    http://wiki.micasaverde.com/index.php/Luup_Lua_extensions#function:_set_failure
                    There need to be a few more changes to the ZWay module in the plugin too.
                    I’ll post a new version shortly, so that it’ll be in the baseline.
                      ZWay development branch v21.1.19 has a fix.
                      As well as setting CommFailure, it also sets CommFailureTime, and the internal device status, which turns the plugin's device banner red on both AltUI and the openLuup console interfaces.
                      As I've said many times, this whole plugin was just a prototype and it seriously need rewriting to improve maintainability... but, nevertheless, it does work quite well.
                        wrote on last edited by PerH
                        #31
                        It definately does. (work well, that is) Thanks!
                          Token lost again today..
                          The z-way-server.log seems to be about z-wave communication only, wonder if I can find traces of wtf is happening with the token somewhere as well?
                            Is this exactly 7 days after it was refreshed?
                              nope. 9 days..
                              • P Offline
                                P Offline
                                powisquare
                                Updated openLuup to v. 21.6.8 yesterday. I notice the z-way bridge has lost connection. and requires login. When I go to device/actions there is no way to enter credentials - only a login button.
                                  Ooh, good spot! NO idea where that's gone. Will take a look.
                                    @powisquare
                                    This should be fixed in latest development version (v21.6.12c)
                                    ...I've obviously become careless recently (although this is a strange one needing further work.)
                                    • P Offline
                                      P Offline
                                      powisquare
                                      All good - much appreciated.
                                        152.9k
