  2. Hardware
  3. Z-Wave.me
  4. z-way-server ubuntu install
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
PerHP
Z-Wave.me
38 Posts 5 Posters 19.5k Views 6 Watching
    sender
    Ok, I update the firmware of the stick a few times.
    Now trying to include in Vera... but got stuck after many minutes:
    I do get the fact that when all is well this product should be awesome. But having spent so many times (and money) and took so many hurdles to get things going, this is where my journey ends and I would like to thank you all kindly for all help and effort. I really hope one day z-wave will see the light but I think this way, it will only get darker. Don't get me wrong, there is always a small group of enthusiasts to which I also wanted to belong but with SO MANY TROUBLES, User side (mine/me) or technology side this is too many steps too far for me.
    Thanks again and it was a very pleasant view to have my vera devices in z-way for a very little while (around 15 minutes) about 2 weeks ago.
    A BIG THANK YOU AGAIN!
    Update: just took A LOT of time?:
    but still no devices... like last stick (2 weeks ago):
      You got an error because you tried to exclude a device from z-way when the exclusion process needs to start from the master controller. You need to set the vera in exclusion mode and then go to z-way to "leave the network".
      The way you did it, the vera has not configured the z-way controller yet. It just included it. Because it is an unknown device, the vera buggy autoconfiguration will not work. You have to disable auto configuration on the vera to get rid of that error.
      All z-way does when you hit the leaving the network button, is to wakeup the z-way's zwave chip. It is expecting the master controller to be in exclude mode. If it isn't it will fail and this is by design.
      When adding a secondary z-wave controller, you have to think of it as just an additional device on the network. That's all it is. Everything you did using the vera remains the same. Nothing has changed. Configuring devices, including, excluding... all the same. You would be doing the same thing if you included another vera or any other controller or even any other device and needed to exclude it.
      Understanding how zwave works under the hood is not very complicated and essential but most of your problems are caused by vera's incomplete implementation of z-wave network control making things very obscure.
      If you had started from clean from z-way, you would have a much simpler system. If you want to run a dual controller, setup, you will need to learn how the z-wave topology and commands work at the most basic level. If you want a clean and simple z-wave system, you are better off getting rid of the vera and forget everything about it.
      S 2 Replies Last reply
        sender
        @rafale77 said in z-way-server ubuntu install:
        I want! But there is a way between Vera <--> homeassitant and Z-way <--> homeassistant. Well 2 ways. 1 is migrating and 2, the most important one, there is nothing for z-way in home assistant, the MQTT plugin is buggy, installation is not straight forward etc...
          sender
          I did not try to exclude anything in z-way. I did that excatly: set vera in exclusion and "leave network" in z-way, that works well! Only the other way around doesn't, the inclusion in the network (Include into network). In the screenshot you may see (Re-)inclusion started but that shows also when I did "include into network".
            sender
            #22
            See, unparing works well:
              #23
              I see. Sorry if I misunderstood.
              The only time I have seen this is when the vera is in its typical crash hang up mode. The vera has started to include a device and its command queue got into wait mode therefore never completing the inclusion. In that case, I would repeat it until it works. It is a vera problem, no different from all the problems including secure class devices the vera has been struggling with.
              Again, when you do it this way, z-way is no more than an additional device on the vera network and has all the same problems the vera has with secure class devices.
              S 1 Reply Last reply
                sender
                This sounds logical, but this would be the 5th time then... I am running out of patience...
                • S sender
                  @sender
                  Yep, blame vera... I took me over 50 attempts and 3 hours on the phone with support to pair a Yale lock. It also took me hundreds of attempts to pair a vision ZP3111-5 securely. You can probably see in the old place my sharing of experience about secure class inclusion success probability, something that blacey mitigated by rebooting the vera just before the inclusion attempt. This varies a lot with what you have going on in your zwave network. The vera takes patience. Something I ran out of which triggered the migration.
                  I also know that you are committed to home assistant as your automation controller. Sorry, I don't have a good answer for it. As you already know, I vastly prefer openLuup for two reasons: 1. I prefer lua 2. Home assistant automation engine is not as powerful and would require node-red to match openLuup's capability as a front end. At that point, why not just run openLuup+z-way and use home assistant for what it is good at: an integration bridge.
                    @sender
                    sender
                    #26
                    @rafale77 Home-assistant is currently the new star in my network... where Vera was just a few weeks ago homeassistant is now... and truly EVERTYTHING IS IN and it works 95-100 time directly... the only PROPER thing missing is a GOOD Z-wave bridge in which Vera as such doesn't do a very bad job at all, weren't it the fact that the z-wave part and device support for that is just not as stable as I want... But on the other hand, the openzwave, zwave2mqtt, QT openzwave (the new beast of hass) and all other "openzwave" falls away with the z-way potential (I have seen)... but the latter is not integrated in homeassistant... so I and completely frustrated here... BTW my entire house is already noded-red... SO SIMPLE!
                      If this (node-red+homeassistant) is your preferred approach, I would recommend moving to hubitat, there is a custom component for it on home-assistant. It is a much better implementation of zwave and zigbee than vera. Otherwise you will have to wait for the z-way component (which is in the works?). From all my testing, vera has become pretty much the worse zwave implementation available. I am sure there are worse ones but I have not tried them. openzwave is a little better, hubitat is much better and homeseer and z-way are top notch.
                        sender
                        Hubitat cloud/subscription-free?
                          hubitat was created by a few smartThing users who got tired of the obvious misuse and abuse of the cloud so you can see it as a local version of SmartThing. It uses the same language and device drivers along with many of the same concepts.
                            sender
                            thanks, will look into. As I see now this is not an "official" integration for homeassistant but a so called custom component...
                              sender
                              Is hubitat so new? https://hubitat.com/products It's unbuyable 🙂
                                sender
                                Rafale, thanks again. I quit, 7th time. Thanks and maybe speak later. (I may not swear, but be lucky one can't hear me)
                                  I had one, and only gave it away after migrating to z-way as I saw it as a backup solution.
                                  For device support, it does not support S2 unlike z-way and homeseer. It uses a mostly community driven device driver development which is shared with SmartThings so it truly supports every device (except S2 ones) unlike the vera and ezlo which rely on a library and forced preset device list. The one controller which really supports everything zwave is Z-way.
                                  It also doesn't really support being a secondary controller and has some quirks when setup that way. I know, I tried...
                                  It is not new at all, it is actually a couple of years old. I have had mine for at least 2 years.
                                  As for the message on the vera about waiting for the name, it is the vera attempting to configure the z-way controller. You can ignore it by setting the z-way device in vera to no auto configure. It is normal by vera standard. What you should see though is the vera device list in z-way.
                                  When using two controllers, you should also set the primary as SUC/SIS. (should be device 1, the vera). That way you can use z-way to include devices and you can also run the "request network updates from SUC/SIS" if z-way did not get the device list from the vera.
                                  The inclusion process for zwave goes like this (I posted a graph somewhere on this forum too):
                                  controller set in include mode -> client device wakeup -> controller adds device to its network list and sends HomeID and DeviceID -> client device gets both IDs, saves them and send ack frame back -> controller sends node info frame (NIF) to device -> client responds with list of supported command classes -> If security is supported controller sends security key exchange frame -> Then device updates neighbor nodes and sends its neighbor list to controller->after it is complete if client is controller, it will send a get network info to controller -> controller responds with list of devices.
                                  The vera tends to fail at sending security keys as it hangs there easily so everything behind it will not happen.
                                  You can manually force everything to happen except for the security key exchange which... I actually managed to do it by manually inserting the key in the z-way controller and bypass this entire process.
                                    sender
                                    Thank you, my z-way adventure is over. The Virtual Machine is shutdown.
                                    I will monitor communication around it and if there is a supported home assistant integration I will give it another try.
                                    I just added another zigbee device in my deconz (container in homeassistant) and instantly works... Just want to say, that if z-wave wants to keep seeing the light it should be made stable, by whoever wants to do so (vera, z-way, openzwave)...
                                    Thanks again!
                                      Curl trouble:
                                      x@x:/usr/lib/x86_64-linux-gnu$ sudo apt-get -y install libcurl3
                                      Reading package lists... Done
                                      Building dependency tree
                                      Reading state information... Done
                                      Package libcurl3 is not available, but is referred to by another package.
                                      This may mean that the package is missing, has been obsoleted, or
                                      is only available from another source
                                      However the following packages replace it:
                                        libcurl4
                                      E: Package 'libcurl3' has no installation candidate
                                      • PerHP PerH
                                        Curl trouble:
                                          libcurl4
                                        #36
                                        @PerH
                                        The problem is that libcurl3 is not in the standard repo you have listed.
                                        assuming you are on ubuntu download it from here:
                                        Ubuntu – Error
                                        You need to pick from the correct platform.
                                        wget --url you can paste from the link above--
                                        i.e
                                        wget http://no.archive.ubuntu.com/ubuntu/pool/universe/c/curl3/libcurl3_7.58.0-2ubuntu2_amd64.deb
                                        downloading from the norwegian mirror for x64
                                        Then run
                                        dpkg -i libcurl3_7.58.0-2ubuntu2_amd64.deb
                                        might need sudo authority to install.
                                        Edit: Another idiot way to do it is to not install libcurl3 at all and instead create a symbolic link for libcurl3 to call libcurl4 (That's how I am running mine 🤘 )
                                        sudo ln -s /usr/local/x86_64-linux-gnu/libcurl-gnutls.so.4 /usr/local/x86_64-linux-gnu/libcurl-gnutls.so.3
                                        sudo ln -s /usr/local/x86_64-linux-gnu/libcurl.so.4 /usr/local/x86_64-linux-gnu/libcurl.so.3
                                        Note that you will need to find where your libcurl library was installed. I just gave you the ubuntu location.
                                          the GUI is up and running now, but i can't update the vendor list, nor start inclusion mode.. any clues?
                                          this funny message is showing in the log..
                                          trying to start inclusion mode:
                                          [2020-09-29 22:29:05.117] [I] [zway] Max number of devices (1) reached
                                          trying to update vendor list:
                                          [2020-09-29 22:26:33.433] [I] [core] Notification: error (core): Error has occured during updating the Z-Wave devices list
                                          I realize it can be annoying with all these noob questions, can only hope you bear with me. 🙂
                                            158.2k
