  3. Z-Wave.me
  4. Install z-way on ubuntu 20 - ssl error
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
Z-Wave.me
2 Posts 1 Posters 855 Views 1 Watching
    sender
    when I install ubuntu 20 and try to install z-way with this:
    sudo wget -c https://storage.z-wave.me/z-way-server/z-way-server-Ubuntu-v3.0.6.tgz -O - | sudo tar -xz -C /opt/z-way-server
    or
    sudo wget -c https://storage.z-wave.me/z-way-server/z-way-server-Ubuntu-v3.0.6.tgz --no-check-certificate -O - | sudo tar -xz -C /opt/z-way-server
    I get:
    --2020-05-10 08:13:33-- https://storage.z-wave.me/z-way-server/z-way-server-Ubuntu-v3.0.6.tgz
    Resolving storage.z-wave.me (storage.z-wave.me)... 46.20.244.36
    Connecting to storage.z-wave.me (storage.z-wave.me)|46.20.244.36|:443... connected.
    OpenSSL: error:1425F102:SSL routines:ssl_choose_client_version:unsupported protocol
    Unable to establish SSL connection.
    gzip: stdin: unexpected end of file
    tar: Child returned status 1
    tar: Error is not recoverable: exiting now
    It seems the z-wave.me sit is using older ssl and ubuntu is not allowing me to use it... how can I overcome this?
      sender
      nevermind, i skipped the "s"
      sudo wget --no-check-certificate -c http://storage.z-wave.me/z-way-server/z-way-server-Ubuntu-v3.0.6.tgz --no-check-certificate -O - | sudo tar -xz -C /opt/z-way-server
        160.0k
