  3. Home Assistant
  4. HA-Vera Energy Usage Deprecated since 2022.4.0
HA and AI
Play Audio through Home Assistant Voice Unit
Migrating from Vera Plus to Home Assistant (or other?)
New HA instance
PerHP
Lovelace initial setup
PerHP
MatohlM
PerHP
HA Bridge oddity
Odd behavior in HA
TTS gone in HA/MSR?
https not allowed in reactor?
4 Posts 3 Posters 1.2k Views 3 Watching
  • MatohlM Offline
    MatohlM Offline
    Matohl
    Relates to Vera integration in Home Assistant
    Just for you to be aware.
    If you are using plugs (or whatever) in Vera to measure energy for your appliances this is deprecated in 2022.4.0 since the HA integration to Vera is not updated and maintained anymore.
    2022.3.8:
    2022.4.3:
    Time to move away from Vera for z-wave ...
    Link to HA thread:
    Apr 8, 2022
    Update 2022.4.0/ Remove energy usage/ VERA
    Yes, it can truly be a hard time to keep up with all the changes and sadly that no one maintains Vera no more. The REST sensor can make it live a bit longer at least for now… sensor: - platform: rest name: "ender_kwh" resource: http://IP_OF_VERA:3480...
      If you're using Reactor (as in your signature), the data is available through VeraController. If you need to get it back into HA, there's MQTTController and other mechanisms.
      MatohlM 1 Reply Last reply
        I'm feeding my electric meters to HA using mqtt. House one is coming from Vera, solar from shelly em. In both cases I'm not using the official integrations.
          MatohlM Offline
          MatohlM Offline
          Matohl
          @toggledbits Yes, I am aware of that and this is how I use it with the rules in MSR but for redundancy (and dashboards) I also use the Vera integration in Home Assistant. I have not yet dived into the world of MQTT. 😁
            114.8k
