  3. Home Assistant
  4. Migrating from Vera Plus to Home Assistant (or other?)
HA and AI
Play Audio through Home Assistant Voice Unit
New HA instance
PerHP
Lovelace initial setup
PerHP
MatohlM
PerHP
HA Bridge oddity
Odd behavior in HA
TTS gone in HA/MSR?
https not allowed in reactor?
verahome assistantopen luareactor
55 Posts 13 Posters 35.7k Views 13 Watching
    sammy2
    So I got to here but am going to set it aside for now.
    How do I add a Z-Wave Adaptor? I currently have a HomeSEER Smart Stick Model SA370-2 Z-Wave Plus USB Dongle I'd like to use unless I need to get something else?
      @sammy2 Feel free to message me direct and we can go to some kind of more interactive communications. I used Virtualbox (although I was on Mac) with the defaults and it took me about 10 minutes
      sammy2
      @CatmanV2 said in Migrating from Vera Plus to Home Assistant (or other?):
      I'm probably at the point to need some remote assistance in completing the installation.. I'll be available Friday morning around 5am PDT.
        Hiya. Just updating my HA box which seems to be taking a long time!
        Are you on Whatsapp or similar?
        S 1 Reply Last reply
          sammy2
          @CatmanV2
          WhatsApp is on my phone. Sorry I didn't catch your response earlier.
          I've got it up and running but am having issues with the USB Driver loading the USB Serial Port in Z-Wave JS. Here's the log:
          [06:45:50] INFO: Successfully send discovery information to Home Assistant.
          2024-08-16T13:45:52.981Z DRIVER   ███████╗        ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗          ██╗ ███████╗
          2024-08-16T13:45:52.994Z DRIVER   version 12.11.2
          2024-08-16T13:45:52.997Z DRIVER
          Logging to file:
          	/config/zwave_2024-08-16.log
          2024-08-16T13:46:02.088Z DRIVER   Failed to open the serial port: Error: I/O error setting custom baud rate of 1
                                            15200
          Unable to start driver ZWaveError: Failed to open the serial port: Error: I/O error setting custom baud rate of 115200 (ZW0100)
              at Driver.openSerialport (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1336:9)
              at Immediate.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1171:5) {
            code: 100,
            context: undefined,
            transactionSource: undefined
          [13:46:02] WARNING: Halt add-on
          s6-rc: info: service legacy-services: stopping
          s6-rc: info: service legacy-services successfully stopped
          s6-rc: info: service legacy-cont-init: stopping
          s6-rc: info: service legacy-cont-init successfully stopped
          s6-rc: info: service fix-attrs: stopping
          s6-rc: info: service fix-attrs successfully stopped
          s6-rc: info: service s6rc-oneshot-runner: stopping
          s6-rc: info: service s6rc-oneshot-runner successfully stopped
          s6-rc: info: service s6rc-oneshot-runner: starting
          s6-rc: info: service s6rc-oneshot-runner successfully started
          s6-rc: info: service fix-attrs: starting
          s6-rc: info: service fix-attrs successfully started
          s6-rc: info: service legacy-cont-init: starting
          cont-init: info: running /etc/cont-init.d/config.sh
          [09:33:32] INFO: Both 'network_key' and 's0_legacy_key' are set and match. All ok.
          [09:33:41] INFO: Soft-reset set to automatic
          [09:33:41] INFO: Virtual Machine detected, disabling soft-reset
          cont-init: info: /etc/cont-init.d/config.sh exited 0
          cont-init: info: running /etc/cont-init.d/structure.sh
          cont-init: info: /etc/cont-init.d/structure.sh exited 0
          s6-rc: info: service legacy-cont-init successfully started
          s6-rc: info: service legacy-services: starting
          services-up: info: copying legacy longrun zwave_js (no readiness notification)
          s6-rc: info: service legacy-services successfully started
          [09:33:57] INFO: Successfully send discovery information to Home Assistant.
          2024-08-16T16:34:05.537Z DRIVER   ███████╗        ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗          ██╗ ███████╗
          2024-08-16T16:34:05.555Z DRIVER   version 12.11.2
          2024-08-16T16:34:05.559Z DRIVER
          Logging to file:
          2024-08-16T16:34:14.741Z DRIVER   Failed to open the serial port: Error: I/O error setting custom baud rate of 1
                                            15200
            code: 100,
            context: undefined,
          [16:34:15] WARNING: Halt add-on
          [09:34:50] INFO: Both 'network_key' and 's0_legacy_key' are set and match. All ok.
          [09:34:56] INFO: Soft-reset set to automatic
          [09:34:56] INFO: Virtual Machine detected, disabling soft-reset
          [09:35:05] INFO: Successfully send discovery information to Home Assistant.
          2024-08-16T16:35:09.664Z DRIVER   ███████╗        ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗          ██╗ ███████╗
          2024-08-16T16:35:09.676Z DRIVER   version 12.11.2
          2024-08-16T16:35:09.678Z DRIVER
          Logging to file:
          I'm wondering if I need to reset the dongle in HomeSEER first before attempting to use it with HA?
          Here's some additional screen grabs which may be of interest:
          Then after some additional trying I got this when adding a Z-Wave Device:
          Unfortunately, I'm in a remote session and cannot continue to attempt to pair the device.
            sammy2
            Additional logging that came up after the poste above:
                                            Z-Wave API version:         9 (legacy)
                                                Z-Wave chip type:           EFR32ZG14 / ZGM130S
                                                node type                   Controller
                                                controller role:            primary
                                                controller is the SIS:      true
                                                controller supports timers: false
                                                Z-Wave Classic nodes:       1
            2024-08-16T16:52:35.072Z CNTRLR   querying version info...
            2024-08-16T16:52:35.116Z CNTRLR   received version info:
                                                controller type: Bridge Controller
                                                library version: Z-Wave 7.17
            2024-08-16T16:52:35.122Z CNTRLR   querying protocol version info...
            2024-08-16T16:52:35.259Z CNTRLR   received protocol version info:
                                                protocol type:             Z-Wave
                                                protocol version:          7.17.1
                                                appl. framework build no.: 344
                                                git commit hash:           30303030303030303030303030303030
            2024-08-16T16:52:35.267Z CNTRLR   querying controller capabilities...
            2024-08-16T16:52:35.315Z CNTRLR   received controller capabilities:
                                                is the SUC:           true
                                                started this network: true
                                                SIS is present:       true
                                                was real primary:     true
            2024-08-16T16:52:35.317Z CNTRLR   querying serial API setup capabilities...
            2024-08-16T16:52:35.342Z CNTRLR   supported serial API setup commands:
                                              · GetSupportedCommands
                                              · SetTxStatusReport
                                              · SetLongRangeMaximumTxPower
                                              · SetPowerlevel
                                              · GetLongRangeMaximumTxPower
                                              · GetPowerlevel
                                              · GetMaximumPayloadSize
                                              · GetLongRangeMaximumPayloadSize
                                              · GetRFRegion
                                              · SetRFRegion
                                              · SetNodeIDType
            2024-08-16T16:52:35.343Z CNTRLR   querying max. payload size...
            2024-08-16T16:52:35.372Z CNTRLR   maximum payload size: 46 bytes
            2024-08-16T16:52:35.374Z CNTRLR   supported Z-Wave features:
                                                · SmartStart
            2024-08-16T16:52:35.377Z CNTRLR   Querying configured RF region...
            2024-08-16T16:52:35.398Z CNTRLR   The controller is using RF region USA
            2024-08-16T16:52:35.400Z CNTRLR   Current RF region (USA) differs from desired region (USA (Long Range)), config
                                              uring it...
            2024-08-16T16:52:35.425Z CNTRLR   Changed RF region to USA (Long Range)
            2024-08-16T16:52:35.426Z CNTRLR   Querying configured max. Long Range powerlevel...
            2024-08-16T16:52:35.472Z CNTRLR   The max. LR powerlevel is 14.0 dBm
            2024-08-16T16:52:35.473Z CNTRLR   Querying configured Long Range channel information...
            2024-08-16T16:52:35.513Z CNTRLR   received Z-Wave Long Range channel information:
                                                channel:                         Unsupported
                                                supports auto channel selection: false
            2024-08-16T16:52:35.516Z CNTRLR   Performing soft reset...
            2024-08-16T16:52:35.561Z CNTRLR   Waiting for the controller to reconnect...
            2024-08-16T16:52:36.777Z CNTRLR   reconnected and restarted
            2024-08-16T16:52:36.779Z CNTRLR   Switching serial API to 16-bit node IDs...
            2024-08-16T16:52:36.783Z CNTRLR   querying Z-Wave Long Range capabilities...
            2024-08-16T16:52:36.815Z CNTRLR   Switching to 16-bit node IDs successful
            2024-08-16T16:52:36.900Z CNTRLR   received Z-Wave Long Range capabilities:
                                                max. payload size: 148 bytes
                                                nodes:
            2024-08-16T16:52:36.902Z CNTRLR   Switching serial API to 16-bit node IDs...
            2024-08-16T16:52:36.940Z CNTRLR   Switching to 16-bit node IDs successful
            2024-08-16T16:52:36.942Z CNTRLR   querying controller IDs...
            2024-08-16T16:52:36.967Z CNTRLR   received controller IDs:
                                                home ID:     0xcbaf673c
                                                own node ID: 1
            2024-08-16T16:52:36.970Z CNTRLR   Enabling TX status report...
            2024-08-16T16:52:37.032Z CNTRLR   Enabling TX status report successful...
            2024-08-16T16:52:37.033Z CNTRLR   finding SUC...
            2024-08-16T16:52:37.050Z CNTRLR   This is the SUC
            2024-08-16T16:52:37.205Z CNTRLR   Interview completed
            Starting server on <all interfaces>:3000
            2024-08-16T16:52:37.294Z CNTRLR   [Node 001] Beginning interview - last completed stage: None
            2024-08-16T16:52:37.297Z CNTRLR   [Node 001] new node, doing a full interview...
            2024-08-16T16:52:37.300Z CNTRLR » [Node 001] querying protocol info...
            ZwaveJS server listening on <all interfaces>:3000
            2024-08-16T16:52:37.767Z CNTRLR « [Node 001] received response for protocol info:
                                              basic device class:    Static Controller
                                              generic device class:  Static Controller
                                              specific device class: PC Controller
                                              node type:             Controller
                                              is always listening:   true
                                              is frequent listening: false
                                              can route messages:    true
                                              supports security:     false
                                              supports beaming:      true
                                              maximum data rate:     100000 kbps
                                              protocol version:      3
            2024-08-16T16:52:37.770Z CNTRLR   [Node 001] Interview stage completed: ProtocolInfo
            2024-08-16T16:52:37.806Z CNTRLR   [Node 001] Embedded device config loaded
            2024-08-16T16:52:37.807Z CNTRLR   [Node 001] Interview stage completed: OverwriteConfig
            2024-08-16T16:52:37.810Z CNTRLR   [Node 001] Interview completed
            2024-08-16T16:52:37.812Z CNTRLR   [Node 001] The node is ready to be used
            2024-08-16T16:52:37.813Z CNTRLR   All nodes are ready to be used
            2024-08-16T16:52:37.818Z CNTRLR   [Node 001] The node is alive.
            2024-08-16T16:52:37.819Z CNTRLR   Interviewing nodes and/or determining their status:
            New client
            Client disconnected
            Code 1000:
            New client
              sammy2
              I probably want to update the f/w but where to find the file??
                Well looks like you got this working, bar the update? What happens when you hit the update at the bottom?
                  sammy2
                  It gives me instructions. I had to go to HomeSEER's website to perform the update. I just finished that task and am restarting the HA VM now.
                    You got this!
                      sammy2
                      Almost! LOL
                        Well I don't run my Z-wave on HA. I have it as an add on device. I have AltUI on a NUC with Mosquitto, and then HA on a Pi
                          sammy2
                          I'm not going to bother with using rigpapa's (ToggledBits) update from Vera to HA using MSR as I currently have two thermostats and three switches connected to Vera since the move from my previous house required a decommission of that whole system. I really have set up any reactors in Vera for these devices so I'll just un-include them from Vera and include them in HA. What do you think, @toggledbits ?
                            sammy2
                            with Mosquitto,
                            Hmm..
                            Should I be doing this instead?? 😧
                              #37
                              Well not necessarily! I didn't want multiple hosts but HA does Alexa voice way better than Vera plug in did, then Owntracks needs Mosquitto and blows iPhone geofencing into the weeds. I solve my problems my way.
                              Off hand I can't think of anything else that uses Mosquitto, but I know it's there. HA is pretty damned powerful, I now have Deebot and Tuya devices in there, but I still use MSR on OpenLuup for all my reactions.
                              Black CatB 1 Reply Last reply
                                There's plenty of ways to do it better, I'm sure. I have a Synology NAS so I could run Docker, but jut didn't.....
                                And I should as my NUC is old. <chews fingernails>
                                  sammy2
                                  Successful f/w update:
                                    sammy2
                                    This is a 5010U i3 NUC and the MoBo has an 8/12/2015 build date according the CPUID or Belarc Advisor:
                                    Processor a
                                    2.10 gigahertz Intel Core i3-5010U
                                    64 kilobyte primary memory cache
                                    256 kilobyte secondary memory cache
                                    3072 kilobyte tertiary memory cache
                                    64-bit ready
                                    Multi-core (2 total)
                                    Hyper-threaded (4 total)
                                    Main Circuit Board b
                                    Board: Intel Corporation NUC5i3RYB H41000-503
                                    Serial Number: GERY53900Q75
                                    Bus Clock: 100 megahertz
                                    UEFI: Intel Corporation RYBDWi35.86A.0350.2015.0812.1722 08/12/2015
                                    It's been in a box for going on 5 years now. I think I just got it for the heck of it when I got it and haven't really used it too much except to do some testing with Emby Beta a while back. I'm going to remove everything I don't need from it and dedicate it to HA.
                                      Well it's looking good so far!
                                        sammy2
                                        https://shop.homeseer.com/products/free-software-bundle-1
                                        Might do this for the Series 800 dongle. Thoughts?
                                          Never used it, sorry!
                                            163.8k
