  3. Home Assistant
  4. HA and AI
HA and AI
Play Audio through Home Assistant Voice Unit
Migrating from Vera Plus to Home Assistant (or other?)
New HA instance
PerHP
Lovelace initial setup
PerHP
MatohlM
PerHP
HA Bridge oddity
Odd behavior in HA
TTS gone in HA/MSR?
https not allowed in reactor?
HA and AI
4 Posts 3 Posters 830 Views 3 Watching
      In my experience I have found that it will just make up random lines, so you have to monitor is very closely and always tell it not to change anything else other than what you have requested.
      It is good for making large repetitive changes though.
        You do. And I will upgrade my observation that it's wrong / produces code that simply doesn't work far far more often than it produces correct code. So I feel a certain kinship 🙂
        Saves me bothering the experts here, and actually is helping learn a lot faster since the iterations are quicker.
          It surely depends on the model. I’ve seen great results with Claude 4.5, Gemini 3 and GPT 5+. I’m lucky to have all them accessible thru GitHub CoPilot Pro.
          But I agree. Giving the best context with your instructions surely makes a difference.
            128.9k
