  3. Home Assistant
  4. EspHome acquired by Nabu Casa
HA and AI
Play Audio through Home Assistant Voice Unit
Migrating from Vera Plus to Home Assistant (or other?)
New HA instance
PerHP
Lovelace initial setup
PerHP
MatohlM
PerHP
HA Bridge oddity
Odd behavior in HA
TTS gone in HA/MSR?
https not allowed in reactor?
1 Posts 1 Posters 558 Views 1 Watching
    Paulus Schoutsen  /  Mar 17, 2021
    Nabu Casa has acquired ESPHome
    Nabu Casa has acquired ESPHome to ensure that the project can continue to flourish as a free and open source project.
      140.7k
