  2. Hardware
  3. Z-Wave.me
  4. Use Scenes (2x/ 3x click) from Fibaro Roller Shutter 2 in openluup with zway bridge
Z-Wave Future....
Z-Wave.me
Z-Wave.me
Docker container for Z-Way
Z-Wave.me
Migration to Virtualisation
Z-Wave.me
Z-Wave.me
UZB Firmware update failed!
Z-Wave.me
Z-Wave RF optimization
Z-Wave.me
E
Z-Wave.me
z-way-server new release
Z-Wave.me
Z-way backup strategy
For all systems backup is a vital part of the long-term usability. I thought that I describe my set up with Z-way so far. Hopefully others can fill in with their backup thoughts as well. I am sure that there are much more streamlined ways of doing this and hope to learn from you all. I run Z-way on a Raspberry Pi 3B+ with a daughter RaZberry card. In order to reduce the risk of getting corrupt SD cards I have it running off an SSD. So far this works very well. Setting it up was really easy just reading a standard Raspbian image onto the SSD. The only minor obstacle was that I had to test a few old 2.5" enclosures to find one that the Pi liked. The Pi is then also powered via an UPS, hopefully this will avoid problems in the event of power outages. In order to backup Z-way I have so far done manual backups from the regular Smarthome backup & restore function creating .zab files and from the Expert UI creating .zbk files. As far as I have understood the .zab files which are bigger contain more information than the .zbk files. The strategy so far has been to make backup files after each inclusion/exclusion. Also before updating Z-way. I have yet to test restoring from these files. From Smarthome it is also possible to set up cloud backup. I have not yet set up this as I need to decide that it is safe enough to do so. On the other hand I had this set up on my two Veras. It would have been nice to be able to schedule a local backup of Z-way instead of having to put them in the cloud, perhaps from OpenLuup via the Z-way bridge? In addition to the built in backup function I try to do complete image copies of the SD cards on my Pi's with Win32DiskImager. When I moved to an SSD the image file grew to the size of the SSD since it is a raw copy including all the empty space. Image files of 160GB are not practical to handle so I found a good instruction on how to shrink the .img file with Gparted in Linux: https://steemit.com/raspberrypi/@wizzle/shrink-raspberry-pi-images-using-windows-virtualbox-running-raspberry-pi-desktop By shrinking the .img file with Gparted it is now a more reasonable 4GB. These file are stored on my NAS for safekeeping. The strategy here so far is to make a new image file before updating Z-way and to use these in combination with more frequent Z-way backups. I have tested restoring a Gparted shrinked .img file to the SSD when my Z-way for some strange reason became unreachable through the regular UI but remained reachable through the Expert UI. Always good to test the restore function and to see that it works. The downside of the .img strategy is that I need to power-off the Pi for a while when making the backup. However if the Z-way backup files work then the complete .img backup need not be done so very often. //ArcherS
Z-Wave.me
Z-way video tutorials
P
Z-Wave.me
Lifeline/TKB switches
P
Z-Wave.me
Switched from RaZberry to UZB
K
Z-Wave.me
P
Z-Wave.me
Rpi kit
P
Z-Wave.me
z-way-server 3.1.0 release
Z-Wave.me
UZB Long Range
Z-Wave.me
Z-Wave.me
Z-Wave.me
Aeon Multisensor 6 issue
PerHP
Z-Wave.me
27 Posts 4 Posters 13.3k Views 4 Watching
  • E Edwin1972
    I have installed my UZB1 stick on my RP4 and want to megrate my device form my Vera to z-way. Now I want to use my Roller shutter 2 in z-way.mev as a scene controller. This is activated by 2x / 3x clicks on the switch. This works perfectly with vera (verabridge) in openluup and reactor using variable LastSceneID and LastScenetime.
    Fibaro documentation:
    When using z-way.me and z-way bridge it works differently. In reactor I see the variable below. I don't know how to use it. Maybe someone else can help me.
    @edwin1972
    I think it works the same, It is just that z-way bridge has not yet been set up to port these variables/command classes to openLuup. I may take a deeper look when I get some more time. It is a busy weekend for me this week.
    • E Offline
      E Offline
      Edwin1972
      thanks all for quick response. @rafale77 it's has no rush so I respect your time
      • E Edwin1972
        @edwin1972
        Just looking quickly into it: From the documentation you shared, there are several operating modes to this switch which you need to setup using the user configuration parameter 14 and/or 10.
        1.What configuration are you using for these 2 parameters? (maybe look at the expertUI into the expert command screen and look for the configurations)
        2.Depending on the configuration used, the behavior should then be identical to the vera: It should report that the scene was activated using the LastSceneTime called LastUpdate in zway but associated with the specific scene number 12, 13, 14 or 16 (hold/release/2xclick/1xclick) which is where you should see the event. Oddly the z-way bridge, and therefore z-way, is posting scene codes 14, 16, 24, 25 and 26 but I have not read the full documentation. It would be interesting to see if you see any of these variables update in z-way when you activate each scene event from the scene controller.
        • E Offline
          E Offline
          Edwin1972
          I have set the following parameters in Vera
          I have set the following parameters in Z-wave.me
          By scene activation, z-way.me created a number of buttons like this. When I press this button, the relevant scene is activated. In ReactorOpenLuup The variable zway_Remote_2-0-0-14-S_LastUpdate change but the variable zway_Remote_2-0-0-14-S stays ON. None of the variables change to the value of sceneID (14,16,24,25 or 26)
          • E Edwin1972
            @edwin1972
            @edwin1972 said in Use Scenes (2x/ 3x click) from Fibaro Roller Shutter 2 in openluup with zway bridge:
            I am not using my scene controllers to trigger scenes but as direct association buttons to turn on and off groups of devices so forgive my ignorance. My understanding of how the scene controllers work is that when you physically toggle a scene, it will just send a command class to update the LastUpdate variable. The zway_remote_xxx is a virtual device attempting to represent the scene as a button. The fact that it stays on is expected (I think the vera used to do the same thing as you would have to trigger an off scene to turn the button off) as the fibaro doesn't have a corresponding off scene. There may be a plugin for this specific type of scene controller on z-way to make the virtual device turn off some time after it triggers.
            Now, if like me you don't use the z-way smarthome interface and will be interracting with openLuup, then the variable zway_Remote_2-0-0-14-S_LastUpdate getting updated is the only thing which is needed to trigger your scene. You could just add a variable watch on this variable for the specific scene you want to trigger on openLuup and do the same for each specific variable. Am I missing something?
              @edwin1972
              @rafale77 said in Use Scenes (2x/ 3x click) from Fibaro Roller Shutter 2 in openluup with zway bridge:
              see:
              @akbooer said in Use Scenes (2x/ 3x click) from Fibaro Roller Shutter 2 in openluup with zway bridge:
              A warning about any variables from the ZWay bridge which start with zway_ ...
              ...they are only really there for development purposes, and they are special, in that they do not trigger a watch when their value is changed. For any recognised device, their values should get translated into more familiar serviceId/variable names which are able to be watched for changes.
                Ahh ok, I'll get on it then. Should be tomorrow or so.
                  No, no. This should NOT be changed. But if you're converting that to an 'ordinary' variable, that's fine.
                    Yes, That's how I understood it 👅 . I was not going to change the generic behavior... just adding support to the command class.
                      Not owning the device or anything similar is making things a bit complicated. I am taking guesses here:
                      @akbooer, this device is reporting a command class 0 which should be recognized by the bridge correctly as a scene controller. However it needs to create multiple "sl_SceneActivated" and "LastSceneTime" variables corresponding to instance 0, then for each of the meta 14, 16, 24, 25 and 26 which correspond to "scene numbers".
                      @Edwin1972, for a start, can you make sure the the bridged device on openLuup uses this device_file "D_SceneController1.xml" as its attribute? There is a possibility that this alone will get you very close to the finish line.
                      • E Offline
                        E Offline
                        Edwin1972
                        I am not familiar with this . I don't understand what you want to know. I would like to provide you with information, but I do not quite understand what you are asking. Can you give me some more detail how to give your requested information.
                        These are my settings:
                          Yes! This is very helpful. Now the only confusion I have is about how you intend on using this controller. Is it still intended to be a roller shutter switch + scene capability or are you intending for it to become a scene controller?
                          Edit: Try the file below which should enable at least the scene last update variable to get updated. Ideally it would be better to create a child device for the scene controller portion of it but for now it adds new variables to the windowcovering device. I also don't know how it handles multiple "scene" containers as it should be creating one variable for each but some additional changes may be required to make that happen.
                          L_ZWay2.lua 2.zip
                          E 2 Replies Last reply
                            L_ZWay2.lua 2.zip
                            E Offline
                            E Offline
                            Edwin1972
                            @rafale77 I had found time again to get started with your answer. I have been getting the error message below for 3 days
                            I log in with admin and password but does not give a result.
                            I can just log in to z-way.me and the devices will do their job.
                              L_ZWay2.lua 2.zip
                              E Offline
                              E Offline
                              Edwin1972
                              @rafale77 It was still the intention to use both the roller shutter switch + scene controller. Vera with Reactor can handle it.
                              When the login error is resolved I will use the zip file
                                The authentication problem is likely an expired token...
                                • E Offline
                                  E Offline
                                  Edwin1972
                                  Thanks for your comment. I do not understand what you mean. Maybe you know how to fix this.
                                  • E Edwin1972
                                    @edwin1972
                                    You may have forgotten how to establish a login session:
                                    You need to go under the openLuup console and use the action screen of the z-way bridge in the console.
                                    This will log you in. Then to prevent your security token from expiring, you need to go make it permanent by going into the z-way smart home UI under options/my settings and click on the hour glass for the token you just established to make it an infinite loop:
                                    • E Offline
                                      E Offline
                                      Edwin1972
                                      #21
                                      Thanks for the information. The z-way bridge is working again. Now I want to use the zip file. Before I maybe demolish things, just a question. Do I have to copy the content of L_ZWay2.lua in Lua test?
                                        #22
                                        No you don't. The L_Zway2 file will be loaded by the z-way bridge plugin. Just make sure that the implementation file in the plugin device is I_ZWay2.xml.
                                        E 1 Reply Last reply
                                        • E Offline
                                          E Offline
                                          Edwin1972
                                          Check, Implementation file in the plugin device is I_ZWay2.xml.
                                            165.5k
