  3. Home Assistant
  4. Migrating from Vera Plus to Home Assistant (or other?)
HA and AI
New HA instance
Lovelace initial setup
MatohlM
HA Bridge oddity
Odd behavior in HA
TTS gone in HA/MSR?
https not allowed in reactor?
verahome assistantopen luareactor
55 Posts 13 Posters 33.8k Views 13 Watching
  • ? Offline
    ? Offline
    A Former User
      Late posting, just saw this thread.
      Welcome to abused Vera users club. I switched almost 2 years ago now and never looked back. When Vera Plus came out, it had such protentional and a loyal user base with great developers. I was running Vera Plus for I think 8 or 9 years, and had been experiencing deteriorating support from both Vera/Ezlo itself, as well as broken plugins that I constantly had to try to work around. When I switched, I had been monitoring the evolution of Ezlo, but it never seemed ready for prime time for me.
      If you used Reactor on Vera, MSR is your answer. You can migrate your existing rules from Reactor on Vera to MSR easily.
      Others have mentioned you can use Vera as a Z-wave radio. This is true, however, it's only capable of so much. If you want to use newer devices, Vera just can't take full advantage. I'm running my Home Assistant setup on a Rpi 4 with a Aeotec Zwave stick, and 80 Z-wave devices on the network, with hardly an issue. 75% of the devices are 700 series or newer with support for S2 encryption (won't get that on Vera Plus). I run MSR on my Fedora NAS server, and they work well together.
      I'm constantly amazed at the possible integrations that I couldn't even dream about on Vera Plus.
        sammy2
        Finally dug the NUC out of the garage. Getting ready to do with this. I'll post more ?? soon I suppose.
          sammy2
          So I got to here but am going to set it aside for now.
          How do I add a Z-Wave Adaptor? I currently have a HomeSEER Smart Stick Model SA370-2 Z-Wave Plus USB Dongle I'd like to use unless I need to get something else?
            @sammy2 Feel free to message me direct and we can go to some kind of more interactive communications. I used Virtualbox (although I was on Mac) with the defaults and it took me about 10 minutes
            sammy2
            @CatmanV2 said in Migrating from Vera Plus to Home Assistant (or other?):
            I'm probably at the point to need some remote assistance in completing the installation.. I'll be available Friday morning around 5am PDT.
              Hiya. Just updating my HA box which seems to be taking a long time!
              Are you on Whatsapp or similar?
              S 1 Reply Last reply
                sammy2
                @CatmanV2
                WhatsApp is on my phone. Sorry I didn't catch your response earlier.
                I've got it up and running but am having issues with the USB Driver loading the USB Serial Port in Z-Wave JS. Here's the log:
                [06:45:50] INFO: Successfully send discovery information to Home Assistant.
                2024-08-16T13:45:52.981Z DRIVER   ███████╗        ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗          ██╗ ███████╗
                2024-08-16T13:45:52.994Z DRIVER   version 12.11.2
                2024-08-16T13:45:52.997Z DRIVER
                Logging to file:
                	/config/zwave_2024-08-16.log
                2024-08-16T13:46:02.088Z DRIVER   Failed to open the serial port: Error: I/O error setting custom baud rate of 1
                                                  15200
                Unable to start driver ZWaveError: Failed to open the serial port: Error: I/O error setting custom baud rate of 115200 (ZW0100)
                    at Driver.openSerialport (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1336:9)
                    at Immediate.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1171:5) {
                  code: 100,
                  context: undefined,
                  transactionSource: undefined
                [13:46:02] WARNING: Halt add-on
                s6-rc: info: service legacy-services: stopping
                s6-rc: info: service legacy-services successfully stopped
                s6-rc: info: service legacy-cont-init: stopping
                s6-rc: info: service legacy-cont-init successfully stopped
                s6-rc: info: service fix-attrs: stopping
                s6-rc: info: service fix-attrs successfully stopped
                s6-rc: info: service s6rc-oneshot-runner: stopping
                s6-rc: info: service s6rc-oneshot-runner successfully stopped
                s6-rc: info: service s6rc-oneshot-runner: starting
                s6-rc: info: service s6rc-oneshot-runner successfully started
                s6-rc: info: service fix-attrs: starting
                s6-rc: info: service fix-attrs successfully started
                s6-rc: info: service legacy-cont-init: starting
                cont-init: info: running /etc/cont-init.d/config.sh
                [09:33:32] INFO: Both 'network_key' and 's0_legacy_key' are set and match. All ok.
                [09:33:41] INFO: Soft-reset set to automatic
                [09:33:41] INFO: Virtual Machine detected, disabling soft-reset
                cont-init: info: /etc/cont-init.d/config.sh exited 0
                cont-init: info: running /etc/cont-init.d/structure.sh
                cont-init: info: /etc/cont-init.d/structure.sh exited 0
                s6-rc: info: service legacy-cont-init successfully started
                s6-rc: info: service legacy-services: starting
                services-up: info: copying legacy longrun zwave_js (no readiness notification)
                s6-rc: info: service legacy-services successfully started
                [09:33:57] INFO: Successfully send discovery information to Home Assistant.
                2024-08-16T16:34:05.537Z DRIVER   ███████╗        ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗          ██╗ ███████╗
                2024-08-16T16:34:05.555Z DRIVER   version 12.11.2
                2024-08-16T16:34:05.559Z DRIVER
                Logging to file:
                2024-08-16T16:34:14.741Z DRIVER   Failed to open the serial port: Error: I/O error setting custom baud rate of 1
                                                  15200
                  code: 100,
                  context: undefined,
                [16:34:15] WARNING: Halt add-on
                [09:34:50] INFO: Both 'network_key' and 's0_legacy_key' are set and match. All ok.
                [09:34:56] INFO: Soft-reset set to automatic
                [09:34:56] INFO: Virtual Machine detected, disabling soft-reset
                [09:35:05] INFO: Successfully send discovery information to Home Assistant.
                2024-08-16T16:35:09.664Z DRIVER   ███████╗        ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗          ██╗ ███████╗
                2024-08-16T16:35:09.676Z DRIVER   version 12.11.2
                2024-08-16T16:35:09.678Z DRIVER
                Logging to file:
                I'm wondering if I need to reset the dongle in HomeSEER first before attempting to use it with HA?
                Here's some additional screen grabs which may be of interest:
                Then after some additional trying I got this when adding a Z-Wave Device:
                Unfortunately, I'm in a remote session and cannot continue to attempt to pair the device.
                  sammy2
                  Additional logging that came up after the poste above:
                                                  Z-Wave API version:         9 (legacy)
                                                      Z-Wave chip type:           EFR32ZG14 / ZGM130S
                                                      node type                   Controller
                                                      controller role:            primary
                                                      controller is the SIS:      true
                                                      controller supports timers: false
                                                      Z-Wave Classic nodes:       1
                  2024-08-16T16:52:35.072Z CNTRLR   querying version info...
                  2024-08-16T16:52:35.116Z CNTRLR   received version info:
                                                      controller type: Bridge Controller
                                                      library version: Z-Wave 7.17
                  2024-08-16T16:52:35.122Z CNTRLR   querying protocol version info...
                  2024-08-16T16:52:35.259Z CNTRLR   received protocol version info:
                                                      protocol type:             Z-Wave
                                                      protocol version:          7.17.1
                                                      appl. framework build no.: 344
                                                      git commit hash:           30303030303030303030303030303030
                  2024-08-16T16:52:35.267Z CNTRLR   querying controller capabilities...
                  2024-08-16T16:52:35.315Z CNTRLR   received controller capabilities:
                                                      is the SUC:           true
                                                      started this network: true
                                                      SIS is present:       true
                                                      was real primary:     true
                  2024-08-16T16:52:35.317Z CNTRLR   querying serial API setup capabilities...
                  2024-08-16T16:52:35.342Z CNTRLR   supported serial API setup commands:
                                                    · GetSupportedCommands
                                                    · SetTxStatusReport
                                                    · SetLongRangeMaximumTxPower
                                                    · SetPowerlevel
                                                    · GetLongRangeMaximumTxPower
                                                    · GetPowerlevel
                                                    · GetMaximumPayloadSize
                                                    · GetLongRangeMaximumPayloadSize
                                                    · GetRFRegion
                                                    · SetRFRegion
                                                    · SetNodeIDType
                  2024-08-16T16:52:35.343Z CNTRLR   querying max. payload size...
                  2024-08-16T16:52:35.372Z CNTRLR   maximum payload size: 46 bytes
                  2024-08-16T16:52:35.374Z CNTRLR   supported Z-Wave features:
                                                      · SmartStart
                  2024-08-16T16:52:35.377Z CNTRLR   Querying configured RF region...
                  2024-08-16T16:52:35.398Z CNTRLR   The controller is using RF region USA
                  2024-08-16T16:52:35.400Z CNTRLR   Current RF region (USA) differs from desired region (USA (Long Range)), config
                                                    uring it...
                  2024-08-16T16:52:35.425Z CNTRLR   Changed RF region to USA (Long Range)
                  2024-08-16T16:52:35.426Z CNTRLR   Querying configured max. Long Range powerlevel...
                  2024-08-16T16:52:35.472Z CNTRLR   The max. LR powerlevel is 14.0 dBm
                  2024-08-16T16:52:35.473Z CNTRLR   Querying configured Long Range channel information...
                  2024-08-16T16:52:35.513Z CNTRLR   received Z-Wave Long Range channel information:
                                                      channel:                         Unsupported
                                                      supports auto channel selection: false
                  2024-08-16T16:52:35.516Z CNTRLR   Performing soft reset...
                  2024-08-16T16:52:35.561Z CNTRLR   Waiting for the controller to reconnect...
                  2024-08-16T16:52:36.777Z CNTRLR   reconnected and restarted
                  2024-08-16T16:52:36.779Z CNTRLR   Switching serial API to 16-bit node IDs...
                  2024-08-16T16:52:36.783Z CNTRLR   querying Z-Wave Long Range capabilities...
                  2024-08-16T16:52:36.815Z CNTRLR   Switching to 16-bit node IDs successful
                  2024-08-16T16:52:36.900Z CNTRLR   received Z-Wave Long Range capabilities:
                                                      max. payload size: 148 bytes
                                                      nodes:
                  2024-08-16T16:52:36.902Z CNTRLR   Switching serial API to 16-bit node IDs...
                  2024-08-16T16:52:36.940Z CNTRLR   Switching to 16-bit node IDs successful
                  2024-08-16T16:52:36.942Z CNTRLR   querying controller IDs...
                  2024-08-16T16:52:36.967Z CNTRLR   received controller IDs:
                                                      home ID:     0xcbaf673c
                                                      own node ID: 1
                  2024-08-16T16:52:36.970Z CNTRLR   Enabling TX status report...
                  2024-08-16T16:52:37.032Z CNTRLR   Enabling TX status report successful...
                  2024-08-16T16:52:37.033Z CNTRLR   finding SUC...
                  2024-08-16T16:52:37.050Z CNTRLR   This is the SUC
                  2024-08-16T16:52:37.205Z CNTRLR   Interview completed
                  Starting server on <all interfaces>:3000
                  2024-08-16T16:52:37.294Z CNTRLR   [Node 001] Beginning interview - last completed stage: None
                  2024-08-16T16:52:37.297Z CNTRLR   [Node 001] new node, doing a full interview...
                  2024-08-16T16:52:37.300Z CNTRLR » [Node 001] querying protocol info...
                  ZwaveJS server listening on <all interfaces>:3000
                  2024-08-16T16:52:37.767Z CNTRLR « [Node 001] received response for protocol info:
                                                    basic device class:    Static Controller
                                                    generic device class:  Static Controller
                                                    specific device class: PC Controller
                                                    node type:             Controller
                                                    is always listening:   true
                                                    is frequent listening: false
                                                    can route messages:    true
                                                    supports security:     false
                                                    supports beaming:      true
                                                    maximum data rate:     100000 kbps
                                                    protocol version:      3
                  2024-08-16T16:52:37.770Z CNTRLR   [Node 001] Interview stage completed: ProtocolInfo
                  2024-08-16T16:52:37.806Z CNTRLR   [Node 001] Embedded device config loaded
                  2024-08-16T16:52:37.807Z CNTRLR   [Node 001] Interview stage completed: OverwriteConfig
                  2024-08-16T16:52:37.810Z CNTRLR   [Node 001] Interview completed
                  2024-08-16T16:52:37.812Z CNTRLR   [Node 001] The node is ready to be used
                  2024-08-16T16:52:37.813Z CNTRLR   All nodes are ready to be used
                  2024-08-16T16:52:37.818Z CNTRLR   [Node 001] The node is alive.
                  2024-08-16T16:52:37.819Z CNTRLR   Interviewing nodes and/or determining their status:
                  New client
                  Client disconnected
                  Code 1000:
                  New client
                    sammy2
                    I probably want to update the f/w but where to find the file??
                      Well looks like you got this working, bar the update? What happens when you hit the update at the bottom?
                        sammy2
                        It gives me instructions. I had to go to HomeSEER's website to perform the update. I just finished that task and am restarting the HA VM now.
                          You got this!
                            sammy2
                            Almost! LOL
                              Well I don't run my Z-wave on HA. I have it as an add on device. I have AltUI on a NUC with Mosquitto, and then HA on a Pi
                                sammy2
                                I'm not going to bother with using rigpapa's (ToggledBits) update from Vera to HA using MSR as I currently have two thermostats and three switches connected to Vera since the move from my previous house required a decommission of that whole system. I really have set up any reactors in Vera for these devices so I'll just un-include them from Vera and include them in HA. What do you think, @toggledbits ?
                                  sammy2
                                  with Mosquitto,
                                  Hmm..
                                  Should I be doing this instead?? 😧
                                    #37
                                    Well not necessarily! I didn't want multiple hosts but HA does Alexa voice way better than Vera plug in did, then Owntracks needs Mosquitto and blows iPhone geofencing into the weeds. I solve my problems my way.
                                    Off hand I can't think of anything else that uses Mosquitto, but I know it's there. HA is pretty damned powerful, I now have Deebot and Tuya devices in there, but I still use MSR on OpenLuup for all my reactions.
                                    Black CatB 1 Reply Last reply
                                      There's plenty of ways to do it better, I'm sure. I have a Synology NAS so I could run Docker, but jut didn't.....
                                      And I should as my NUC is old. <chews fingernails>
                                        sammy2
                                        Successful f/w update:
                                          sammy2
                                          This is a 5010U i3 NUC and the MoBo has an 8/12/2015 build date according the CPUID or Belarc Advisor:
                                          Processor a
                                          2.10 gigahertz Intel Core i3-5010U
                                          64 kilobyte primary memory cache
                                          256 kilobyte secondary memory cache
                                          3072 kilobyte tertiary memory cache
                                          64-bit ready
                                          Multi-core (2 total)
                                          Hyper-threaded (4 total)
                                          Main Circuit Board b
                                          Board: Intel Corporation NUC5i3RYB H41000-503
                                          Serial Number: GERY53900Q75
                                          Bus Clock: 100 megahertz
                                          UEFI: Intel Corporation RYBDWi35.86A.0350.2015.0812.1722 08/12/2015
                                          It's been in a box for going on 5 years now. I think I just got it for the heck of it when I got it and haven't really used it too much except to do some testing with Emby Beta a while back. I'm going to remove everything I don't need from it and dedicate it to HA.
                                            148.6k
