  3. Home Assistant
  4. Migrating from Vera Plus to Home Assistant (or other?)
HA and AI
Play Audio through Home Assistant Voice Unit
New HA instance
PerHP
Lovelace initial setup
PerHP
MatohlM
PerHP
HA Bridge oddity
Odd behavior in HA
TTS gone in HA/MSR?
https not allowed in reactor?
verahome assistantopen luareactor
55 Posts 13 Posters 35.7k Views 13 Watching
  • S sammy2
    Sorry I've not posted back yet..
    Lot's of suggestions here. Keep in mind the last thing I programed was something in college decades ago in Fortran so I don't know any of the current languages. I need something dumbed down and preferably graphics based.
    I actually have a HomeSeer Smart Stick + actually, Model number SA 370-2, 908.42 MHz (Said G3 in my initial post) and would like to use my NUC for the controller but for whatever reason it is packed away and I cannot find it.
    Can I start on my Ryzen 3700x and then migrate it over to the NUC when I dig it out of storage?
    I'm thinking HA might be more for me because I need it dumbed down a bit but where to start? Links?
    @sammy2 Yes migrating HA setups is not difficult! HA setup nowadays is more GUI based so you won't have to deal with much code. Setting up MSR you will have to but its very basic straightforward stuff and a lot of useful info is available on the docs. Plus we're all here to help!
      No, really, no coding required these days.
      Although if you did want to dip your toe in, I’d certainly recommend Lua, which is what Vera (and openLuup) plugins use. It’s modern, but not a difficult move from Fortran (which is what I cut my teeth on when at school.)
        mrFarmer
        Hi, instead of full DYI I switched to Hubitat. Nice thing is that MSR supports both Vera and Hubitat so you can migrate in phases. I'm running MSR in Docker on a NAS. I added HA for some integrations that do not exist for Hubitat, also using docker, and also linked with MSR. Last I use openLuup to run some plugins that came from Vera and have not found good replacements for. All logic that is complex or needs more than one platform sits in MSR.
        When you move a (zwave) device from Vera to Hubitat (or HA) it is just a matter of changing to old device to the new in MSR rules and the wife does not even notice 🙂
        For fun I also added InfluxDB and Grafana and am now learning to build some nice dashboard as a sort of datamine replacement. Using MSR you can feed Influx form any of the connected systems. HA and Hubitat have InfluxDB connections.
        As you see, many options to ditch Vera.
          sammy2
          Sorry guys.. Been working 60 hour weeks currently so I've been back burnering this!
          At any rate, I think I'm going to go with HA and am still looking for answers to these questions:
          I think though I might want to find the NUC because I thought I read a few weeks ago to run HA on an intel PC, there's a HA (Linux?) os and the NUC would need to be formatted. I'm not going to do that with my everyday work horse and media server!
          PablaP 1 Reply Last reply
          • S sammy2
            @sammy2 I would install HA using a virtual machine on your windows device. Then once you find your NUC install HA OS on it. This is all assuming you intend to run HA OS. Take a look at this page to see your options for install types. Backup and restore from the same install type is no problem.
              @Pabla this is exactly what I did. Worked like a charm, although a little nerve wracking do to the lack of progress bars. It takes a while as well 🙂
              Swapped the IP addresses over and the NUC stepped into the HA role with barely a flicker
                sammy2
                So how do I run a virtual machine? Gotta back up a bit for me!
                PablaP CatmanV2C 2 Replies Last reply
                • S sammy2
                  @sammy2 there's ton of videos online on how to get up and running with HA but here's their guide on how to run HA OS on a virtual machine on windows
                  • S sammy2
                    @sammy2 Feel free to message me direct and we can go to some kind of more interactive communications. I used Virtualbox (although I was on Mac) with the defaults and it took me about 10 minutes
                    S 1 Reply Last reply
                      sammy2
                      Thanks to everyone for your input! It'll be a couple of days before I can get deep into this because I have very limited time these days to dabble.
                      • ? Offline
                        ? Offline
                        A Former User
                          Late posting, just saw this thread.
                          Welcome to abused Vera users club. I switched almost 2 years ago now and never looked back. When Vera Plus came out, it had such protentional and a loyal user base with great developers. I was running Vera Plus for I think 8 or 9 years, and had been experiencing deteriorating support from both Vera/Ezlo itself, as well as broken plugins that I constantly had to try to work around. When I switched, I had been monitoring the evolution of Ezlo, but it never seemed ready for prime time for me.
                          If you used Reactor on Vera, MSR is your answer. You can migrate your existing rules from Reactor on Vera to MSR easily.
                          Others have mentioned you can use Vera as a Z-wave radio. This is true, however, it's only capable of so much. If you want to use newer devices, Vera just can't take full advantage. I'm running my Home Assistant setup on a Rpi 4 with a Aeotec Zwave stick, and 80 Z-wave devices on the network, with hardly an issue. 75% of the devices are 700 series or newer with support for S2 encryption (won't get that on Vera Plus). I run MSR on my Fedora NAS server, and they work well together.
                          I'm constantly amazed at the possible integrations that I couldn't even dream about on Vera Plus.
                            sammy2
                            Finally dug the NUC out of the garage. Getting ready to do with this. I'll post more ?? soon I suppose.
                              sammy2
                              So I got to here but am going to set it aside for now.
                              How do I add a Z-Wave Adaptor? I currently have a HomeSEER Smart Stick Model SA370-2 Z-Wave Plus USB Dongle I'd like to use unless I need to get something else?
                                sammy2
                                @CatmanV2 said in Migrating from Vera Plus to Home Assistant (or other?):
                                I'm probably at the point to need some remote assistance in completing the installation.. I'll be available Friday morning around 5am PDT.
                                  Hiya. Just updating my HA box which seems to be taking a long time!
                                  Are you on Whatsapp or similar?
                                    sammy2
                                    @CatmanV2
                                    WhatsApp is on my phone. Sorry I didn't catch your response earlier.
                                    I've got it up and running but am having issues with the USB Driver loading the USB Serial Port in Z-Wave JS. Here's the log:
                                    [06:45:50] INFO: Successfully send discovery information to Home Assistant.
                                    2024-08-16T13:45:52.981Z DRIVER   ███████╗        ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗          ██╗ ███████╗
                                    2024-08-16T13:45:52.994Z DRIVER   version 12.11.2
                                    2024-08-16T13:45:52.997Z DRIVER
                                    Logging to file:
                                    	/config/zwave_2024-08-16.log
                                    2024-08-16T13:46:02.088Z DRIVER   Failed to open the serial port: Error: I/O error setting custom baud rate of 1
        15200
                                    Unable to start driver ZWaveError: Failed to open the serial port: Error: I/O error setting custom baud rate of 115200 (ZW0100)
                                        at Driver.openSerialport (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1336:9)
                                        at Immediate.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1171:5) {
                                      code: 100,
                                      context: undefined,
                                      transactionSource: undefined
                                    [13:46:02] WARNING: Halt add-on
                                    s6-rc: info: service legacy-services: stopping
                                    s6-rc: info: service legacy-services successfully stopped
                                    s6-rc: info: service legacy-cont-init: stopping
                                    s6-rc: info: service legacy-cont-init successfully stopped
                                    s6-rc: info: service fix-attrs: stopping
                                    s6-rc: info: service fix-attrs successfully stopped
                                    s6-rc: info: service s6rc-oneshot-runner: stopping
                                    s6-rc: info: service s6rc-oneshot-runner successfully stopped
                                    s6-rc: info: service s6rc-oneshot-runner: starting
                                    s6-rc: info: service s6rc-oneshot-runner successfully started
                                    s6-rc: info: service fix-attrs: starting
                                    s6-rc: info: service fix-attrs successfully started
                                    s6-rc: info: service legacy-cont-init: starting
                                    cont-init: info: running /etc/cont-init.d/config.sh
                                    [09:33:32] INFO: Both 'network_key' and 's0_legacy_key' are set and match. All ok.
                                    [09:33:41] INFO: Soft-reset set to automatic
                                    [09:33:41] INFO: Virtual Machine detected, disabling soft-reset
                                    cont-init: info: /etc/cont-init.d/config.sh exited 0
                                    cont-init: info: running /etc/cont-init.d/structure.sh
                                    cont-init: info: /etc/cont-init.d/structure.sh exited 0
                                    s6-rc: info: service legacy-cont-init successfully started
                                    s6-rc: info: service legacy-services: starting
                                    services-up: info: copying legacy longrun zwave_js (no readiness notification)
                                    s6-rc: info: service legacy-services successfully started
                                    [09:33:57] INFO: Successfully send discovery information to Home Assistant.
                                    2024-08-16T16:34:05.537Z DRIVER   ███████╗        ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗          ██╗ ███████╗
                                    2024-08-16T16:34:05.555Z DRIVER   version 12.11.2
                                    2024-08-16T16:34:05.559Z DRIVER
                                    Logging to file:
                                    2024-08-16T16:34:14.741Z DRIVER   Failed to open the serial port: Error: I/O error setting custom baud rate of 1
        15200
                                      code: 100,
                                      context: undefined,
                                    [16:34:15] WARNING: Halt add-on
                                    [09:34:50] INFO: Both 'network_key' and 's0_legacy_key' are set and match. All ok.
                                    [09:34:56] INFO: Soft-reset set to automatic
                                    [09:34:56] INFO: Virtual Machine detected, disabling soft-reset
                                    [09:35:05] INFO: Successfully send discovery information to Home Assistant.
                                    2024-08-16T16:35:09.664Z DRIVER   ███████╗        ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗          ██╗ ███████╗
                                    2024-08-16T16:35:09.676Z DRIVER   version 12.11.2
                                    2024-08-16T16:35:09.678Z DRIVER
                                    Logging to file:
                                    I'm wondering if I need to reset the dongle in HomeSEER first before attempting to use it with HA?
                                    Here's some additional screen grabs which may be of interest:
                                    Then after some additional trying I got this when adding a Z-Wave Device:
                                    Unfortunately, I'm in a remote session and cannot continue to attempt to pair the device.
                                      sammy2
                                      Additional logging that came up after the poste above:
        Z-Wave API version:         9 (legacy)
        Z-Wave chip type:           EFR32ZG14 / ZGM130S
        node type                   Controller
        controller role:            primary
        controller is the SIS:      true
        controller supports timers: false
        Z-Wave Classic nodes:       1
                                      2024-08-16T16:52:35.072Z CNTRLR   querying version info...
                                      2024-08-16T16:52:35.116Z CNTRLR   received version info:
        controller type: Bridge Controller
        library version: Z-Wave 7.17
                                      2024-08-16T16:52:35.122Z CNTRLR   querying protocol version info...
                                      2024-08-16T16:52:35.259Z CNTRLR   received protocol version info:
        protocol type:             Z-Wave
        protocol version:          7.17.1
        appl. framework build no.: 344
        git commit hash:           30303030303030303030303030303030
                                      2024-08-16T16:52:35.267Z CNTRLR   querying controller capabilities...
                                      2024-08-16T16:52:35.315Z CNTRLR   received controller capabilities:
        is the SUC:           true
        started this network: true
        SIS is present:       true
        was real primary:     true
                                      2024-08-16T16:52:35.317Z CNTRLR   querying serial API setup capabilities...
                                      2024-08-16T16:52:35.342Z CNTRLR   supported serial API setup commands:
        · GetSupportedCommands
        · SetTxStatusReport
        · SetLongRangeMaximumTxPower
        · SetPowerlevel
        · GetLongRangeMaximumTxPower
        · GetPowerlevel
        · GetMaximumPayloadSize
        · GetLongRangeMaximumPayloadSize
        · GetRFRegion
        · SetRFRegion
        · SetNodeIDType
                                      2024-08-16T16:52:35.343Z CNTRLR   querying max. payload size...
                                      2024-08-16T16:52:35.372Z CNTRLR   maximum payload size: 46 bytes
                                      2024-08-16T16:52:35.374Z CNTRLR   supported Z-Wave features:
        · SmartStart
                                      2024-08-16T16:52:35.377Z CNTRLR   Querying configured RF region...
                                      2024-08-16T16:52:35.398Z CNTRLR   The controller is using RF region USA
                                      2024-08-16T16:52:35.400Z CNTRLR   Current RF region (USA) differs from desired region (USA (Long Range)), config
        uring it...
                                      2024-08-16T16:52:35.425Z CNTRLR   Changed RF region to USA (Long Range)
                                      2024-08-16T16:52:35.426Z CNTRLR   Querying configured max. Long Range powerlevel...
                                      2024-08-16T16:52:35.472Z CNTRLR   The max. LR powerlevel is 14.0 dBm
                                      2024-08-16T16:52:35.473Z CNTRLR   Querying configured Long Range channel information...
                                      2024-08-16T16:52:35.513Z CNTRLR   received Z-Wave Long Range channel information:
        channel:                         Unsupported
        supports auto channel selection: false
                                      2024-08-16T16:52:35.516Z CNTRLR   Performing soft reset...
                                      2024-08-16T16:52:35.561Z CNTRLR   Waiting for the controller to reconnect...
                                      2024-08-16T16:52:36.777Z CNTRLR   reconnected and restarted
                                      2024-08-16T16:52:36.779Z CNTRLR   Switching serial API to 16-bit node IDs...
                                      2024-08-16T16:52:36.783Z CNTRLR   querying Z-Wave Long Range capabilities...
                                      2024-08-16T16:52:36.815Z CNTRLR   Switching to 16-bit node IDs successful
                                      2024-08-16T16:52:36.900Z CNTRLR   received Z-Wave Long Range capabilities:
        max. payload size: 148 bytes
        nodes:
                                      2024-08-16T16:52:36.902Z CNTRLR   Switching serial API to 16-bit node IDs...
                                      2024-08-16T16:52:36.940Z CNTRLR   Switching to 16-bit node IDs successful
                                      2024-08-16T16:52:36.942Z CNTRLR   querying controller IDs...
                                      2024-08-16T16:52:36.967Z CNTRLR   received controller IDs:
        home ID:     0xcbaf673c
        own node ID: 1
                                      2024-08-16T16:52:36.970Z CNTRLR   Enabling TX status report...
                                      2024-08-16T16:52:37.032Z CNTRLR   Enabling TX status report successful...
                                      2024-08-16T16:52:37.033Z CNTRLR   finding SUC...
                                      2024-08-16T16:52:37.050Z CNTRLR   This is the SUC
                                      2024-08-16T16:52:37.205Z CNTRLR   Interview completed
                                      Starting server on <all interfaces>:3000
                                      2024-08-16T16:52:37.294Z CNTRLR   [Node 001] Beginning interview - last completed stage: None
                                      2024-08-16T16:52:37.297Z CNTRLR   [Node 001] new node, doing a full interview...
                                      2024-08-16T16:52:37.300Z CNTRLR » [Node 001] querying protocol info...
                                      ZwaveJS server listening on <all interfaces>:3000
                                      2024-08-16T16:52:37.767Z CNTRLR « [Node 001] received response for protocol info:
        basic device class:    Static Controller
        generic device class:  Static Controller
        specific device class: PC Controller
        node type:             Controller
        is always listening:   true
        is frequent listening: false
        can route messages:    true
        supports security:     false
        supports beaming:      true
        maximum data rate:     100000 kbps
        protocol version:      3
                                      2024-08-16T16:52:37.770Z CNTRLR   [Node 001] Interview stage completed: ProtocolInfo
                                      2024-08-16T16:52:37.806Z CNTRLR   [Node 001] Embedded device config loaded
                                      2024-08-16T16:52:37.807Z CNTRLR   [Node 001] Interview stage completed: OverwriteConfig
                                      2024-08-16T16:52:37.810Z CNTRLR   [Node 001] Interview completed
                                      2024-08-16T16:52:37.812Z CNTRLR   [Node 001] The node is ready to be used
                                      2024-08-16T16:52:37.813Z CNTRLR   All nodes are ready to be used
                                      2024-08-16T16:52:37.818Z CNTRLR   [Node 001] The node is alive.
                                      2024-08-16T16:52:37.819Z CNTRLR   Interviewing nodes and/or determining their status:
                                      New client
                                      Client disconnected
                                      Code 1000:
                                      New client
                                        sammy2
                                        I probably want to update the f/w but where to find the file??
                                          Well looks like you got this working, bar the update? What happens when you hit the update at the bottom?
                                            163.8k
